Soft WDT reset
I use a sp. conection with cayenne is ok, but after sending the data, there is a reset of the soft.
data ok
[150030] Publish: topic 1, channel 1, value 21.000, subkey c, key temp
[150032] Publish: topic 1, channel 2, value 24.000, subkey c, key temp
[150033] Publish: topic 1, channel 3, value 361, subkey lux, key lum
[150038] Publish: topic 1, channel 4, value 0, subkey d, key digital_sensor
Soft WDT reset
stack>>>
which device you are using and can you share the code you have used?
hello, it’s a wemos mini pro
#define CAYENNE_DEBUG
#include <stdio.h>
float T_CUVE, T_SURF ;
int resistance_on;
char DONNE_SERIE_RX[20];
int bufferSize= 64 ;
int nbrecaractere =19;
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
//boolean tempo = 1;
#define VIRTUAL_CHANNEL1 1
#define VIRTUAL_CHANNEL2 2
#define VIRTUAL_CHANNEL3 3
#define VIRTUAL_CHANNEL4 4
char mychar;
  int i=0;
  int T_CUVE_100,T_SURF_100,LDR =0;
  String string1,string2,string3,string4;
 // int tempo =0;
  unsigned long int DELAIS = 0;
  Serial.begin(115200);
  Serial.print("WEMOS 11072019");
    if(Serial.available()) {
      do {
      mychar = Serial.read(); // read char from UART
      Serial.print(mychar);  //test
      while ( mychar != '*');
     DONNE_SERIE_RX[i] = mychar;
      for (i=1; i<19 ; i++ ) {mychar= Serial.read();DONNE_SERIE_RX[i]=mychar;}  //18--> 16
    Serial.print (DONNE_SERIE_RX[0]);Serial.println (DONNE_SERIE_RX[17]);
     if ((DONNE_SERIE_RX[0] == '*') && (DONNE_SERIE_RX[17] =='#')) {  // verifie que les data sont corect
      // sprintf(DONNE_SERIE, "*%04d;%04d;%04d;%1d#\r\n", t1,t2,ldr,resistance_on);
    Serial.println ( "data ok"); //test
    for (i=1; i < nbrecaractere; i++) {
    if ((char)DONNE_SERIE_RX[i]==';') {i++;break;}
     string1+=((char)DONNE_SERIE_RX[i]); }
  // Serial.println(string1);
  for (i; i < nbrecaractere; i++) {
     string2+=((char)DONNE_SERIE_RX[i]);   }
  // Serial.println(string2);
  for (i; i < nbrecaractere+1; i++) {
     string3+=((char)DONNE_SERIE_RX[i]);   }
   if ((char)DONNE_SERIE_RX[i]=='#') {i++;break;}
     string4+=((char)DONNE_SERIE_RX[i]);   }
 //  Serial.println(string3);
      T_CUVE_100=(int)string1.toInt();
      T_CUVE =  float (T_CUVE_100/100);
      T_SURF_100=(int)string2.toInt();
      T_SURF = float( T_SURF_100/100);
      LDR=(int)string3.toInt();
      resistance_on=(int)string4.toInt();
     Cayenne.virtualWrite(1, T_CUVE,"temp","c");
     Cayenne.virtualWrite(2, T_SURF,"temp","c");
     Cayenne.virtualWrite(3, LDR, "lum" ,"lux");
     Cayenne.virtualWrite(4, resistance_on,"digital_sensor","d");
     //Serial.flush();
  do {
what does this code do? can you comment it out and check if you have the same issue.
I collect data on the port serie, I process them and I transmit them in wifi
does this work for you without the cayenne code added?
Your problem is at while ( mychar != '*'); There’s no way to exit that while loop and the watchdog timer is being triggered and resetting the device.
hello, I changed the code. it’s ok, there is no more reset. thank you
adam
      Leader
    July 12
Visit Topic or reply to this email to respond.
In Reply To
ricard97432
    July 12
To unsubscribe from these emails, click here.
-------- Message original --------
