Here is code, i know this must be very basic but I am quite new to this and I have spent quite a lot of time and cannot work out how it works. CHANNEL 1 will work, but I can get channel 2 to work, if i call them both channel 1 with different pins it will only switch one, i would really appreciate to know what I am doing wrong.
Ben
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 5 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
i have made changes to your code. in place of just copy and paste try to understand the code and find out where was the mistake.
#define VIRTUAL_CHANNEL_1 1
#define ACTUATOR_PIN_1 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL_2 2
#define ACTUATOR_PIN_2 5 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
pinMode(ACTUATOR_PIN_1, OUTPUT);
pinMode(ACTUATOR_PIN_2, OUTPUT);
CAYENNE_IN(VIRTUAL_CHANNEL_1)
int value_1 = getValue.asInt();
digitalWrite(ACTUATOR_PIN_1, value_1);
CAYENNE_IN(VIRTUAL_CHANNEL_2)
int value_2 = getValue.asInt();
digitalWrite(ACTUATOR_PIN_2, value_2);
for me:
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL_1, ACTUATOR_PIN_1, value_1);
CAYENNE_LOG(“Channel %d, pin %d, value %”, VIRTUAL_CHANNEL_2, ACTUATOR_PIN_2, value_2);
@gcdodclan what is the issue?
Hi Sharamik, thanks for all help in forum
The code no run for me.
I changed the CAYENNE LOG (VIRTUAL_CHANNEL_1, ACTUATOR_PIN_1, value_1), , and run for me.
Thanks for all
these is just output info in the serial monitor.
