Using current sensor trough ESP8266
I’m trying to use cayenne firmware to receive information from this device:
https://robotdyn.com/current-sensor-acs712-5a.html
I’m trying to use a ESP8266 - CP2102 NodeMCU V3 Lua, to receive the data on my cayenne online dashboard, from a widget that would tell me the current that the sensor is analysing.
Is it possible to do so with cayenne firmware?
are you able to read data from the sensor on to your nodemcu. Once you are done then you can send that data to cayenne using Cayenne.virtualWrite(1, data, "current", "a");
I was not able to send data from the sensor to ESP8266 because I did not find code for it.
What you suggest?
a simple google search gave this https://basicelectronics.in/how-to-interface-acs712-current-sensor-with-nodemcu/
I managed to read data on arduinoIDE serial monitor, connecting the sensor to ESP8266 using this code:
const int sensorIn = A0;
int mVperAmp = 185; // use 185 for 5A, 100 for 20A Module and 66 for 30A Module
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
pinMode(A0, INPUT);
Serial.begin(115200);
delay(10);
Serial.println(F("Init...."));
void loop(){
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707; // sq root
AmpsRMS = (VRMS * 1000)/mVperAmp;
float Wattage = (230*AmpsRMS)-13; //Observed 18-20 Watt when no load was connected, so substracting offset value to get real consumption.
Serial.print(AmpsRMS);
Serial.println(" Amps RMS ");
Serial.print(Wattage);
Serial.println(" Watt ");
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = 1024; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 1000) //sample for 1 Sec
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
/* Serial.print(readValue);
Serial.println(" readValue ");
Serial.print(maxValue);
Serial.println(" maxValue ");
Serial.print(minValue);
Serial.println(" minValue ");
delay(1000); */
// Subtract min from max
result = ((maxValue - minValue) * 5)/1024.0;
return result;
I want to have a graph as a cayenne widget on the online dashboard of the Wattage (sensor data). How and where should I inserted the line you sent?
Cayenne.virtualWrite(1, data, “current”, “a”);
you need to use the cayenne code for esp8266 Cayenne-MQTT-Arduino/examples/Connections/ESP8266 at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub and add the sensor code along with the line i shared above. if you need to change it watt data type then have a look at this Data types for Cayenne MQTT API
I think i’m very close to the objective. But the error: " ‘Wattage’ was not declared in scope " appears when uploading the code to ESP8266:
#define CAYENNE_DEBUG
#define SENSOR_PIN 0 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL 1
char ssid = “–”;
char wifiPassword = “–”;
char username = “–”;
char password = “–”;
char clientID = “–”;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
pinMode(A0, INPUT);
delay(10);
Serial.println(F(“Init…”));
pinMode(SENSOR_PIN, INPUT);
void loop(){
Voltage = getVPP();
VRMS = (Voltage/2.0) 0.707; // sq root
Serial.println(" Amps RMS “);
Serial.println(” Watt “);
checkSensor();
float getVPP()
float result;
/record the maximum sensor value/
Serial.println(” readValue “);
Serial.println(” maxValue “);
Serial.println(” minValue ");
delay(1000); */
return result;
int previousState = -1;
int currentState = -1;
void checkSensor()
if (currentMillis - previousMillis >= 100) {
currentState = digitalRead(SENSOR_PIN);
Cayenne.virtualWrite(1 , Wattage, “Potência”, “W”);
previousState = currentState;
what does this code do?
It’s a code that is working in other project. I used it for having a widget on cayenne dashboard, that gave me information if a movement sensor was activated or not (movement sensor connected to ESP8266, ESP8266 connect via mqtt to cayenne):
//Resistência de 100ohms entre ESP8266 e PIR
char ssid[] = "--";
char wifiPassword[] = "--";
char username[] = "--";
char password[] = "--";
char clientID[] = "--";
#define SENSOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
  Serial.begin(74880);
  pinMode(5, OUTPUT);
  digitalWrite(5,HIGH);
  checkSensor();
void checkSensor()
      Cayenne.virtualWrite(1  , currentState, "digital_sensor", "d");
CAYENNE_IN(0)
  digitalWrite(5, !getValue.asInt());
i am not sure what your code is doing and why you are using it. the error you are getting is because you have not declared Wattage globally.
I removed the code you said didn’t understand.
Now the following error appears (while uploading the code): “stray ‘\stray342’ in program”
char ssid = “”;
char wifiPassword = “”;
char username = “”;
char password = “”;
char clientID = “”;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
pinMode(A0, INPUT);
delay(10);
void loop(){
Voltage = getVPP();
Cayenne.virtualWrite(1, Wattage, “Potência”, “W”);
float getVPP()
float result;
delay(1000); */
return result;
you need to brush your programming knowledge, it is quite bad at the moment. You can start with this https://www.arduino.cc/en/Tutorial/HomePage?from=Main.Tutorials
here is the code that should work:
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
float Wattage = (230 * AmpsRMS) - 13; //Observed 18-20 Watt when no load was connected, so substracting offset value to get real consumption.
  pinMode(A0, INPUT);
  delay(10);
  Serial.println(F("Init…"));
  Voltage = getVPP();
  VRMS = (Voltage / 2.0) * 0.707; // sq root
  AmpsRMS = (VRMS * 1000) / mVperAmp;
float getVPP()
  float result;
  while ((millis() - start_time) < 1000) //sample for 1 Sec
  result = ((maxValue - minValue) * 5) / 1024.0;
  return result;
CAYENNE_OUT_DEFAULT()
  Cayenne.virtualWrite(1, Wattage, "Potência", "W");
I’m sorry, I’m not very good at this as I am a begginer in arduino systems.
Thank you so much for the help and my apologies.
The code works but not correctly. When moving this line:
void loop ()
To before that, the Wattage variable does not “refresh”, it only sends one value to the cayenne widget on the dashboard. As I refered, the code that gives the Wattage values trough the ArduinoIDE trough the serial monitor, has the line of code I wrote above in void loop, because it is constantly looping to read the current values.
How can I solve this problem?
char ssid[] = "";
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
float Wattage;
  pinMode(A0, INPUT);
  delay(10);
  Voltage = getVPP();
float getVPP()
  float result;
  return result;
Working perfectly!
Thank you so much for your patience and help
