Can not connect to remote device
I have a WeMos mini connected to a motor and am trying to get Cayenne to turn it on for a variable period of time.
I have been able to modify ESP8266.ino to achieve this.
I created the device on my dashboard, added a button and a slider. The button turns the motor on/off and the slider turns it on for a variable amount of time set by the slider. The ‘uptime’ display from the ESP8266 code displays the number of mS since powerup.
All works well from either Chrome or Firefox on my Mac.
On my Samsung S6 and my Nexus7 - both running android Cayenne - The On/Off button works, and the “uptime” value that I left in from the original example works, however the slider gives “can not connect to remote device”.
Anybody have any ideas about this?
@jcruz1 @bestes tagging for this bug.
Hey, i really need your help. i want to understand all of this stuff so help
@sagalyusuf3 what problem are you facing?
I’m trying to learn how each device work but it’s not working for me
you have to be more specific and give a bit more information about the problem you are facing.
I am not sure how the replies relate to the problem or the request for ideas.
@jmarchbold the bug you are facing is a new one and the team needs to find the cause between it.
How can I help?
Here is the code:
D5, D6, D7 identify the WeMos pins.
Only D5 is presently used.
D6, D7 relate to the encoder software.
//#define CAYENNE_DEBUG
// #include <Encoder.h>
char ssid[] = "xxxxxx";
char wifiPassword[] = "xxxxx;
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
#define TIME_CHANNEL 3
#define CONTROL_CHANNEL 2
Encoder myEnc(D6, D7);
#define MotorPin D5  // Turn motor on/off
int MotorTime;
  pinMode(MotorPin, INPUT);
  digitalWrite(MotorPin, HIGH);
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN(TIME_CHANNEL)
  MotorTime = getValue.asInt(); // 0 to 255
  CAYENNE_LOG("Channel %d, pin %d, value %d", TIME_CHANNEL, MotorPin, MotorTime);
  // Write the value received to the PWM pin. analogWrite accepts a value from 0 to 255.
  if (MotorTime > 0) {
    Serial.print("Running for ");
    Serial.print(MotorTime);
    Serial.print(" seconds - ");
    pinMode(MotorPin, OUTPUT);
    digitalWrite(MotorPin, LOW);
    delay(MotorTime*1000);
    Serial.println("Stopped");
  else {
CAYENNE_IN(CONTROL_CHANNEL)
  CAYENNE_LOG("Channel %d, pin %d, value %d", CONTROL_CHANNEL, MotorPin, getValue.asInt());
  if (getValue.asInt() > 0) {
    Serial.println("Running...");
  else if (getValue.asInt() == 0) {
    Serial.println("Stopped...");
CAYENNE_IN_DEFAULT()
Here is the screen shot on Mac:
Samsung S6 screenshots:
Thank you so much
Any progress - at the moment I have to take my Mac with me! I would much rather use the Nexus
Any progress?
