Device (Wemos D1 mini) offline in cayenne
I have two wemos d1 devices on the same network.
Of the two I have one with a slight problem on app side (I need to force quit and reopen twice for the buttons to work)
The second device has a more severe problem: It appears offline. But if I blindly open it and press a button, it returns online.
Could you please check my code? thanks `// This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
#define CAYENNE_DEBUG
#include <Adafruit_BMP085_U.h>
#include <SimpleTimer.h>
#include <SPI.h>
//BUTTON declarations
SimpleTimer timer;
const int buttonPin = D8;  // The number of the Pushbutton pin
int buttonState = 0;  // Variable for reading the pushbutton status
long previousMillis = 0;        // will store last time LED was updated
long interval = 3000;           // interval at which to blink (milliseconds)
long currentValue;
float Dtemp;
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "-";
char password[] = "";
char clientID[] = "-";
//DOOR RELAY
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN D1 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
//PANIC RELAY
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN D2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
//ALARM RELAY
#define VIRTUAL_CHANNEL 3
#define ACTUATOR_PIN D3 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
//BIG GATE GATE RELAY
#define VIRTUAL_CHANNEL 4
#define ACTUATOR_PIN D4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
unsigned long lastMillis = 0;
  Serial.begin(74880);
  //SETUP DOOR AS LOW (default locked)
  digitalWrite(D1, LOW);
  pinMode(D1, OUTPUT);
     //SETUP PANIC AS HIGH (default locked)
  digitalWrite(D2, HIGH);
  pinMode(D2, OUTPUT);
  //SETUP ALARM AS HIGH (default locked)
  digitalWrite(D3, HIGH);
  pinMode(D3, OUTPUT);
        //SETUP BIG GATE AS HIGH (default locked)
  digitalWrite(D4, HIGH);
  pinMode(D4, OUTPUT);
    timer.setInterval(1200L, emergencybtn);
void loop()  {
    timer.run();
void emergencybtn()
   //REDBUTTON EMERGENCY
   previousMillis = millis();
   // read the state of the pushbutton value:
   buttonState = digitalRead(buttonPin);
   //The button is pushed
    while (buttonState == HIGH)
       Serial.println(buttonState);
     currentValue = millis() - previousMillis;
     if (currentValue > interval)  //If the button has been pressed for over 7 secs, open it
       // save the last time relays has been turned on
       digitalWrite(D1, HIGH);      //opendoor
       delay(2000);     //give time to get in
      digitalWrite(D1, LOW);    //close it
  yield();
// DOOR RELAY   This function is called when data is sent from Cayenne.
CAYENNE_IN(1)
  if (getValue.asInt() == 0) {
    delay(2000);
  else {
// PANIC RELAY This function is called when data is sent from Cayenne.
CAYENNE_IN(2)
    digitalWrite(D2, LOW);
    delay(3000);
  else {
// ALARM RELAY This function is called when data is sent from Cayenne.
CAYENNE_IN(3)
    digitalWrite(D3, LOW);
    delay(1200);
  else {
// AUTOMATIC PORCH GATE RELAY This function is called when data is sent from Cayenne.
CAYENNE_IN(4)
    digitalWrite(D4, LOW);
    delay(2900);
  else {
this is because you are not sending any data to cayenne to make in online. add this code in your code:
CAYENNE_OUT (13)
