Current is not displayed
hi community, I have connected Arduino UNO (serial USB with cayenne) with PZEM-004, all values are shown except current ones, can you help me?you will find attached the software that I used. Thank you.
//ajout
#include <PZEM004T.h> //https://github.com/olehs/PZEM004T
PZEM004T pzem(11,10);  // RX,TX (D2, D1) on NodeMCU
IPAddress ip(192,168,1,1);
#define CAYENNE_DEBUG
int voltage_cayenne=0;
int current_cayenne;
int power_cayenne=0;
int energy_cayenne=0;
int courant;
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
  pzem.setAddress(ip);
  // Read meter PZEM
    float v = pzem.voltage(ip);
   if(v >= 0.0){     voltage_cayenne =v; }          //V
    float i = pzem.current(ip);
    if(i >= 0.0){    current_cayenne=i;   }  //A   convert  A --->  mA
    float p = pzem.power(ip);
    if(p >= 0.0){    power_cayenne=p;       }      //W
    float e = pzem.energy(ip);
    if(e >= 0.0){    energy_cayenne =e;  }       ///Wh
delay(1000);.
    lastMillis = millis();
    Cayenne.virtualWrite(1,voltage_cayenne);
    Cayenne.virtualWrite(2,current_cayenne*1000);
    Cayenne.virtualWrite(3,power_cayenne);
    Cayenne.virtualWrite(4, energy_cayenne);
    Cayenne.virtualWrite(5, lastMillis);
hi @sara.loukili.lasri do you have a rthernet sield or esp8266. As it is difficult to debug when the USB serial library is used.
Hello, yes I have esp8266 but I must add a resistance of 1kohm in power meter. I tried with Arduino UNO using the serial USB, even when I run in the serial monitor without using cayenne all the values are displayed. but when I try cayenne except the current that is not displayed. I don’t know where is the problem.
Thank you.
connect esp8266 as shield and use this code. follow the steps below. Once you connect add your sensor code to this.
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
char ssid[] = "=";
char wifiPassword[] = "";
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
  //Serial.begin(9600);
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  delay(10);
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Soukd I use ESP82 + Arduino with the power meter or just Esp82? If It just Esp82 can it work without welding the 1k resistance to the SDIC(the card which is inside the power meter?
yes. the PZEM-004 uses serial communication and you have two assign two pins for it from the arduino.
