Hi. I have a problem with showing figures of the temperature. When I just start an arduino it shows the temperature in web browser but after a few seconds it shows 0.0. But in app on my phone it works good. How could I solve this problem? Thank you.
can you share the code you are using?
#include <DHT.h>
#include <Adafruit_Sensor.h>
#define DHTTYPE DHT11
#define DHTPIN 5
#define VIRTUAL_CHANNEL 3
#define ACTUATOR_PIN 4
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "----";
char password[] = "";
char clientID[] = "----";
#define EspSerial Serial
float h;
float t;
bool Umidade = false;
bool Temperatura = false;
DHT dht(DHTPIN, DHTTYPE);
ESP8266 wifi(&EspSerial);
delay(10);
dht.begin();
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT(V1){
//Serial.println("Umidade");
//Check if read failed and try until success
do {
//Read humidity (percent)
h = dht.readHumidity();
delay(1000);
} while (isnan(h));
Cayenne.virtualWrite(V1, h);
CAYENNE_OUT(V2){
//Serial.println("Temperatura");
do {
//Read temperature as Celsius
t = dht.readTemperature();
delay(1000);
} while (isnan(t));
Cayenne.virtualWrite(V2, t);
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
And I have some problems more:
- A have a relay on schedule, it’s working, but not properly, so it’s turning “off”, but doesn’t turn “on” the next day.
- If relay “on” and electricity go down, and then electricity come back, relay stays “off”, however by the schedule it should be “on”.
- It’s always go offline after some time, so you need to restart an arduino.
first delete all the widget from your dashboard. upload this code on your device https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/CommunitySubmitted/DHT/DHT.ino and add the widgets populated by it.
you mean you have two separate schedules to turn OFF and turn ON?
you can store the last of the relay in the EEPROM of the arduino and then read and write the last state to the relay on restart if the arduino.
check your serial monitor for what is causing the issue of disconnect.
Thanks for the sketch. About two separate schedules, I don’t know, it’s look like that:
I will try EEPROM and check serial monitor, but I could do it on weekends. Thank you ones again.
the image you shared does not provide much information on what you are trying to do.
Sorry))) if I understand right, it’s two different schedules.
it should work if they are two separate schedules/events.
So it’s better to make 2 separate schedules or just one?
you have to add two separate schedules for each action at different time.
Yep, that’s what I’ve done, but it’s turning OFF but doesn’t turn ON. Maybe because it’s goes offline every time?
can you PM me your email_id.
Hi again.
I’ve try the sketch that you gave me, it doesn’t work.
Steps:
#include <DHT.h>
char ssid[] = "";
#define DHTPIN 2 // Digital pin connected to the DHT sensor
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
#define TEMPERATURE_VIRTUAL_CHANNEL 1
#define HUMIDITY_VIRTUAL_CHANNEL 2
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor.
delay(10);
delay(10);
// This function is called at intervals to send temperature sensor data to Cayenne in Celsius.
CAYENNE_OUT(TEMPERATURE_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(TEMPERATURE_VIRTUAL_CHANNEL, dht.readTemperature(), "temp", "c");
// This function is called at intervals to send humidity sensor data to Cayenne.
CAYENNE_OUT(HUMIDITY_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(HUMIDITY_VIRTUAL_CHANNEL, dht.readHumidity(), "rel_hum", "p");
Sorry, all good, was my mistake, I forgot to put dht.begin(); sorry
Glad to hear it is working now.
