DHT11 Trigger Not Working
Howdy all?
I have been using Cayenne for a couple of weeks now. I have tried several digital sensors and they all work. The notifications also work. I have started using a DHT11 temperature and humidity sensor. It works and I can display the temperature on my dashboard. However what does not work are notifications based on this sensor readings. I set a notification to be sent to me whenever the temperature exceeds 80 F. I have not been able to receive any notifications so far even after long periods of time where temperature has exceeded the limit.
I did search the forums but nothing has helped so far. My guess is that notifications based on analog values are not working.
Anybody knows what is going on?
I am including my code below so you can see what it does.
#include <DHT.h>
char ssid[] = “ssid”;
char wifiPassword[] = “password”;
char username[] = “cayenne username”;
char password[] = “cayenne password”;
char clientID[] = “client ID”;
DHT dht(D2,DHT11);
float tf;
Serial.begin(115200);
dht.begin();
tf = dht.readTemperature(true);
if ( isnan(tf)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
Cayenne.virtualWrite(1,tf,“temp”,“f”);
Welcome to the community!
Unfortunately there are some known issues with triggers and alerts right now, so they may not work as expected all the time. It’s being worked on and a fix will be rolled out soon.
thanks, have the same problem.
any deadline to solution?
