Raspberry Pi device info (e.g. Pi 2 w/ Raspbian Jessie version 02/26):
Multiple RPi2b’s and a Zero with varing versions of Jessie including 03/18 both wired and WiFi’d into the network
Describe the steps it took to produce the bug / issue:
Workflow-
App install went well.
192.168.1.7, .15, and .23 all already had Cayenne installed under another account - no discovery
192.168.1.25 was a freshly formated SD with 2016-03-18-raspbian-jessie.img on WiFi - no discovery
Pi not discovered.
Multiple Pi 2Bs with jessie 2016-02-09 updated.
Used dropbox to install on
motoE,
android v 4.44,
baseband MSM8610BP-1803.346.31.00R,
kernal 3.4.42-G6bc7ff3 / hudsoncm@ilclbld27 #1 / Tue Jun 24 20:39:20 CDT 2014
Build number KXC21.5-40
Security Enhancements for Android: I do not have this setting
Have static “My Devices” screen not showing any Pi, so “setup” button does nothing.
Better organization to just update this post I think.
Phone and Pi s on same class c network, verified pi s online with ssh.
Used existing account during setup.
I have the last “My devices” page of your screen shots, have not seen the one with radar screen.
Pi not listed when I use phone to scan, I do see my printer though.
We are investigating additional discovery protocols to try and help with this. @Ian I think you mentioned that you don’t have iOS to test, but for anyone else coming across this… it would be helpful if you could compare the iOS app and the Android to see if the iOS app is any better at finding the missing Pi. There are some differences currently in how they detect and we’re working to close the gap.
Bottom line up front. No discovery with Samsung S5, but did get discovery with Nexus 7.
Here are my notes from this afternoon’s experiences with a RPi 3b-
format sd card image with 2016-03-18-raspbian-jessie.img expand and localize no discovery with Samsung S5 Active sudo apt-get update sudo apt-get upgrade reboot no discovery with S5 ssh from phone to RPi ping via ssh from phone
clear cache remove cayenne from phone reinstall cayenne login with regular account installed RPi's are there no discovery of RPi3 confirm on network with ifconfig and ping to 8.8.8.8
And then things got weird, I grabbed my Nexus 7 tablet, you know the one .32a isn’t supposed to work on. Opened Cayenne and only saw the 4 already loaded RPi’s. I hit the reload button once and low and behold-
Then tapping on Ready to use gets me nowhere, so again I back out and reenter Cayenne and this time all 5 RPi’s show up in the device list and seem to work fine.
