Tutorial: Microchip Lora Mote and The Things Network Cayenne integration
The Microchip LoRa Mote is a battery powered demonstration/develop board populated with a 868 or 915 Mhz LoRa module.
It has a micro USB connector for ASCII command communication between the pc and the LoRa module or you can use a PIC programmer to program the on board PIC18LF45K50 MCU. There are 2 versions of this Mote, one with Oled and one with LCD display (This tutorial works for the LCD version)
With this Mote you can send light and temperature to a LoRaWan network like The Things Network (TTN).
Microchip LoRa Mote, Lcd version
In this tutorial I will show you how to visualize the received data from TTN in Cayenne.
I assume that the Mote is working correct; that means, there is a TTN account, you made an Application and the device is correctly registered so, the data is already visible in the TTN Console.
Of course you already have a Cayenne user account.
• Open the Cayenne dashboard and click “Add new” > Device/Widget
• Click LoRa (Beta) > The Things Network
• Scroll down and click the arrow button
• Enter the Device name and the DevEUI (TTN Console > Applications > > manage devices > > Device overview > Device EUI)
• Click the “Add device” button
• Select and copy your Process ID from the browser address and…
• Open the TTN Console and click: (TTN Console > Applications > Integrations + add integration
• Click Cayenne
• Copy your Cayenne Process ID and click: “Acces Key” > “Default Key” > “ Add Integration”
• Your Integration Overview should show “Status Running”
This part is ready and all you have to do now is:
• Go back to the Cayenne Dashboard
• Take the Microchip LoRa Mote and send some data
• See the magic happens in Cayenne :wink:
• No coding or decoding, it all happens in the background. When data comes available, Temperature and Luminosity widgets are automatically created.
Thanks for reading, and by the way, I made a simple 3D printed enclosure for the Microchip LoRa Mote:
Microchip LoRa Mote enclosure
If this is a tutorial you should put “Tutorial” at the title to help people find your post.
Mmmm, perhaps we need a Tutorial label category @bestes ?
Thanks! changed the title
Love the tutorial! I think I will actually move this to the category called ‘The Library’ :slight_smile: which is better category for tutorials like this one. Well done!
Hi Marco,
do you have any pointers on how do do the pre-requisite step:
Best regards
Hi Gregor,
Check if there is a TTN gateway in the neighborhood
Create a TTN account
Enter your Console
Before you can communicate with devices, you will need to add the application to the network and register devices to it.
Add the application
Before a device can communicate via The Things Network you need to register it with an application.
Register your device (the Mote:-)
Send data and check if the data is received in the Console > Application(s) > Data
If everything works fine you can follow the steps for Cayenne integration.
And for more info
RTFM (Read The Friendly Manuals;-)
Kind Regards,
Thanks @marco_rudolph. Let us know if you run into any issues @gregor.wolf , and we’d love to see what you end up making!
Hi Marco,
thank you for the links. I already have a TTN Account and run my own one channel gateway with the Dragino Shield for Raspberry. I have a Dragino Arduino Node sending data in this setup. I’ve got the Microchip Lora Mote in February 2016 at the Mobile World Congress in Barcelona. But I struggle how I get the Mote setup for TTN. Or will it simply just work via OTAA which my local setup does not yet support or? Then I have to wait for my next time in Munich :-).
Best regards
Hi @gregor.wolf,
I know on Loriot, the free account only supports 1 gateway and requires a commercial account to use OTAA. I wonder if TTN is the same?
