I am using an Arduino uno with a 5100 shield. I am just trying to get a button to turn on an led.
it works but very slowly and quite inconsistently. here is my sketch. I would appreciate any suggestions. sincere thanks,
jon
Cayenne Light Switch Example
This sketch shows how to set up a Light Switch with Cayenne.
Steps:
- In the Cayenne Dashboard add a new Light Switch Widget.
- Select a virtual channel number for the widget.
- Set the VIRTUAL_CHANNEL value below to virtual channel you selected.
- Attach the negative leg of an LED to ground and the other leg to the selected digital pin.
Schematic:
[Ground] – [LED] – [Resistor] – [Digital Pin] - Set the ACTUATOR_PIN value below to the pin number you used when connecting your LED.
- Compile and upload this sketch.
- Once the Arduino connects to the Dashboard you can use the widget button to turn the LED on and off.
char username[] = “d8887b60-3aa8-11e8-9f38-9fae3d42ebf0”;
char password[] = “7aef2e8fb1382216d5b33ef6ac160191bfa17eca”;
char clientID[] = “e00cf280-40c5-11e8-9beb-4d400e603e7e”;
#define VIRTUAL_CHANNEL 0
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
