Hello friends, I am testing Cayenne, I started using an ESP8266-07 and a DHT11 sensor, I got it to work properly.
Now I added two buttons to light two LEDs, these are connected directly to pins 2 and 5 with a resistance to ground each as indicated by all examples.
The issue that if I connect the system, is Off Line. If I disconnect the LEDs before connecting the system and then connect them, everything works normally. That is, I have to start the system with the LEDs disconnected.
Is there something wrong with the code? Should I insert a transistor between the doors and the LED?
My sckecht:
//#define CAYENNE_DEBUG
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 0
#define DHTTYPE DHT11
DHT_Unified dht(DHTPIN, DHTTYPE);
char ssid[] = "xxx";
char wifiPassword[] = "xxx";
char username[] = "xxxx";
char password[] = "xxxx";
char clientID[] = "xxxx";
unsigned long lastMillis = 0;
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
dht.begin();
sensor_t sensor;
//Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
lastMillis = millis();
sensors_event_t event;
dht.temperature().getEvent(&event);
Cayenne.celsiusWrite(1, event.temperature);
dht.humidity().getEvent(&event);
Cayenne.virtualWrite(2, event.relative_humidity, "rel_hum", "p");
CAYENNE_IN(6)
if (currentValue == 1)
//do whatever you want when you turn on the button on cayenne dashboard
digitalWrite(2, HIGH);
else
//do whatever you want when you turn off the button on cayenne dashboard
CAYENNE_IN(7)
digitalWrite(5, HIGH);
else
CAYENNE_IN_DEFAULT()
