Newbie needs help
Hi there. some help to solve my problem would be apreciated. i am quite new at cayenne. On arduino solo everything works fine. but now i want to have on/off button for my project (Alarm on lasertrap and pirsensor). to arm/disarm per click on the app. at the moment i am realy confused and changed many things but it doesnt work.
#include <CayenneMQTTESP32.h>
const int buttonPin =23;
const int photoResistor = 22; // Photoresistor at Arduino analog pin A0
const int pirPin = 21;
const int buzzerPin = 19;
const int ledPin = 18;
const int flashPin = 15;
char ssid[] = "xxx";
char pass[]="xxxxxx";
char mqtt_username[] ="xxx";
char mqtt_password[] = "xxx";
char client_id[] = "xxx";
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4
  Cayenne.begin(mqtt_username, mqtt_password, client_id, ssid, pass);
   pinMode(buttonPin, INPUT);
   pinMode(pirPin, INPUT);
   pinMode(buzzerPin, OUTPUT);
   pinMode(ledPin, OUTPUT);
   pinMode(photoResistor, INPUT);
   pinMode(flashPin, OUTPUT);
  int pirDetected = digitalRead(pirPin);
  int detected = digitalRead(photoResistor);
  if ((detected == LOW) || (pirDetected == HIGH))//Abfrage Laser oder PIR Signal
      if (detected == LOW){Serial.println("unerlaubtes Betreten - Lichtschranke wurde unterbrochen!");};
      if (pirDetected == HIGH){Serial.println("Einbruchsversuch - Annäherungssensor wurde aktiviert");};
      for (int i=0;i<=10;i++)     //wie oft blinkenUndPiepesen
        digitalWrite(flashPin, HIGH);
        digitalWrite(ledPin, HIGH);  //Turn led on
        digitalWrite(buzzerPin, LOW);
        delay(150);//wie lange pause bis signalwechsel
        digitalWrite(ledPin, LOW);
        i=i+1;
        delay(10); //wie lange pause bis nächster durchlauf
   else
    digitalWrite(flashPin, LOW);
   delay(50);
CAYENNE_IN(VIRTUAL_CHANNEL)
  int value = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
//if (ACTUATOR_PIN == HIGH)
//else{
//      digitalWrite(ledPin, LOW);
//      digitalWrite(buzzerPin, LOW);
//      digitalWrite(flashPin, LOW);
// This function is called at intervals to send data to Cayenne and keep the device online.
// Will create a temporary green widget on Channel 0, make it permanent by clicking on '+'.
CAYENNE_OUT(0)
  CAYENNE_LOG("Send data for Virtual Channel 0");
  // This command writes the device's uptime in seconds to the Virtual Channel.
  Cayenne.virtualWrite(0, millis() / 1000);
what do you get in the serial monitor when you press the button on the cayenne dashboard?
Hi. thanks for reply.
led for on/off works. but not for my code.
Timestamp
Unit
Values
2020-09-04 5:11:35
Nr2
Pin
c0e83580-eebb-11ea-a67f-15e30d90bbf4
can you try this code:-
Assuming you have added the button on channel 1 and led is connected to digital pin 4.
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
Hi. thank u for your support.
my serial monitor:
18:37:38.615 → [5291025] Channel 1, pin 4, value 0
18:37:39.967 → [5292357] Channel 1, pin 4, value 1
18:37:44.602 → [5296999] Send data for Virtual Channel 0
18:38:00.361 → [5312751] Send data for Virtual Channel 0
18:38:16.115 → [5328503] Send data for Virtual Channel 0
18:38:27.664 → Einbruchsversuch - Annäherungssensor wurde aktiviert
18:38:29.648 → Einbruchsversuch - Annäherungssensor wurde aktiviert
18:38:31.665 → [5344075] Send data for Virtual Channel 0
18:38:33.796 → unerlaubtes Betreten - Lichtschranke wurde unterbrochen!
18:38:44.478 → [5356869] Channel 1, pin 4, value 0
18:38:47.331 → [5359741] Send data for Virtual Channel 0
18:38:54.704 → unerlaubtes Betreten - Lichtschranke wurde unterbrochen!
18:38:57.748 → Einbruchsversuch - Annäherungssensor wurde aktiviert
18:38:59.745 → Einbruchsversuch - Annäherungssensor wurde aktiviert
18:39:02.839 → [5375223] Send data for Virtual Channel 0
where to put the action in the code when channel 1 is on/off? i dont get it…:frowning:
channel 0 is only a chekup - no need
what do you mean by this? does the code I gave turn ON/OFF the led?
Sorry. Its not about the led tis is wirkung… My goal: the Connecticut between led and Main Funktion my alarmsystem. if i turn led on via cayenne( Chanel 1 Status 1) my alarmsystem is armed and Wirkung. If i shut off the lde (Status 0) the System is disarmed.
still i did not understand.
sorry that i can not explain better…here a piece of the code…
still not works…
<void loop()
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
// Write the value received to the digital pin.//when value is 1 run the action //function, if value is 0 skip the action function
if (value ==1)
{ action();}
// i want to skip this if the value (sent from cayenne channel 1 pin4 is 0
// how can i skip the function action() ? this is for shut of the alarmsystem
void action(){
thanks again for your interest and support
[quote=“werthebach, post:9, topic:15199”]
if (value ==1)
{ action();}
[/qunrote]
the action function should only run value is 1 and ignore when 0
Thanks bro. the code compiles without error but it still not works. i got no reaction from laser or pir. i am so sad…
/*Franks AlarmSystem Lasertrap for unallowed entry to the garden. PIR for enemy nearby.
  • Buzzer for Alarmsound, Stroboskobflashlight. For Testing Led. on the planfor later camera for pictures via mobile
    char ssid = “Fluffy”;
    char pass=“Fr@nk&Nel@”;
char mqtt_username =“be7ba900-ba1b-11ea-b767-3f1a8f1211ba”;
char mqtt_password = “c01dbdb7c1c55971d01528bf2bfd347bf4416e6d”;
char client_id = “43c393c0-eeba-11ea-93bf-d33a96695544”;
//laser is dircet 5v and ground ( no pin)
if (value ==1)
{ action();}
void action(){
if (detected == LOW){Serial.println(“unerlaubtes Betreten - Lichtschranke wurde unterbrochen!”);};
if (pirDetected == HIGH){Serial.println(“Einbruchsversuch - Annäherungssensor wurde aktiviert”);};
digitalWrite(buzzerPin, HIGH);
    i=i+1;
else
{ //this is when alarmsystem is offline. i am there so no need for alarm. when i leave i put cayenne led ON to arm the system
digitalWrite(photoResistor, LOW);
delay(50);
// Will create a temporary green widget on Channel 0, make it permanent by clicking on ‘+’.
CAYENNE_OUT(0)
CAYENNE_LOG(“Send data for Virtual Channel 0”);
// This command writes the device’s uptime in seconds to the Virtual Channel.
i don’t understand what you want. Do you want your action function to run continuously when the button value is 1?
Yes. Action should run contiunusly until i put value to 0.
This Sound be the Main switch For the system
you need to call the action function from main loop.
  if (value == 1)
    action();
int value;
