If you got some sensor’s and read their data, you onluy can display the data on the screen.
But a nice Idee should be to have a calculation whith the data.
Example (distance meter) in a water tank every cm 45 liter total hight (max distance 200 cm) (200-distance)*45= amount off liter
If you have standard sensor’s you cant bring this calculation to the sensor him zelf.
This is the custum made off the dash board, you can calculate with in the “TTN Payload” but that data is not availble in Cayenne only thr RAW data I have read.
Thanks for the suggestion. will take note of it.
