add this code at the last:
CAYENNE_IN(1)
int x = getValue.asInt();
Serial.println(x);
digitalWrite(D5, x);
CAYENNE_IN(1)
Serial.println(x);
it don’t work… Maybe somebody have code just for this; i just need actuate one or two pin
can you share the entire code used for this?
I do like this /*
Cayenne Relay Switch Example
This sketch sample file shows how to set up a Relay Switch with Cayenne.
Steps:
char ssid = “-”;
char wifiPassword = “”;
char username = “----”;
char password = “”;
char clientID = “----”;
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
CAYENNE_IN(VIRTUAL_CHANNEL)
if (getValue.asInt() == 0) {
digitalWrite(ACTUATOR_PIN, HIGH);
else {
digitalWrite(ACTUATOR_PIN, LOW);
CAYENNE_IN(1)
Serial.println(x);
But i’ve error during compilation : exit status 1
‘D5’ was not declared in this scope
Is strange why is not possible to work like Raspberry ?
you mentioned you are using esp8266, but the header is for ethernet shield.
raspberry pi uses pi agent and is quite advance and handles most of the work, with minimum effort from the user end.
while with arduino, you have to code according to your need with the support cayenne MQTT library.
I just do what cayenne say me… I’m using esp8266 D1 mini
Is not any solutions to do more friendly ?
Can you give me code wich work and after i can change how i want, i’ve just to konw how it work for my application i don’t need more for moment
which device you are using?
which esp8266 pin have you connected the relay?
i’m using windows for go to cayenne and after i select arduino ( who is my esp8266 )
i’ve connect to PIN D5
i mean, which device (hardware) are you using? is it an esp8266 or arduino?
by this, I am assuming you have a nodemcu or wemos esp8266 development board.
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
#define ACTUATOR_PIN D5
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN(1)
Serial.println(x);
digitalWrite(ACTUATOR_PIN, x);
Plusieurs bibliothèque trouvées pour “CayenneArduinoDefines.h”
Utilisé : D:\Users\Tristan\Documents\Arduino\libraries\Cayenne-MQTT-ESP-master
Non utilisé : D:\Users\Tristan\Documents\Arduino\libraries\CayenneMQTT
exit status 1
I think it don’t take good libraries
navigate to this D:\Users\Tristan\Documents\Arduino\libraries and delete this Cayenne-MQTT-ESP-master folder
D:\Users\Tristan\Desktop\mydevices_MQTT_2\mydevices_MQTT_2.ino:56:15: note: in expansion of macro ‘ACTUATOR_PIN’
exit status 1
which is the board you have selected in your arduino IDE?
i’m using GENERIC ESP8266 MODULES
