Arduino UNO + ESP8266 ESP-01
Hi guys, i have a problem with my proyect, my device don´t send data from cayenne
Serial:
[1576] ESP is not responding
[4087] ESP is not responding
[6597] ESP is not responding
[15366] Connected to WiFi
[15366] Connecting to mqtt.mydevices.com:1883
[15985] Connected
[26007] MQTT connect failed, error 0
My code:
#include <OneWire.h>
OneWire oneWire(8);
unsigned long lastTempUpdate = 0;
char ssid = “RN”;
char wifiPassword = “********”;
char username = “69f8c2b0-46ca-11ea-a38a-d57172a4b4d4”;
char password = “fa8e580b3e8adf4d400c731aa5e722202e3be649”;
char clientID = “7dd4fb50-47c9-11ea-ba7c-716e7f5ba423”;
#define EspSerial Serial1
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(2, 3); // RX, TX
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
sensors.begin();
void loop(){
// float temperatureC = sensors.getTempCByIndex(0);
if ( millis() - lastTempUpdate > 600 ) {
lastTempUpdate = millis();
Cayenne.virtualWrite(0, sensors.getTempCByIndex(0) ,TYPE_TEMPERATURE,UNIT_CELSIUS);
//lastTempUpdate = now;
CAYENNE_IN_DEFAULT()
if you read the intro in the code, the code is not stable for uno and is for devices which have extra serial port like mega.
I was able to solve this problem, I think it was a problem with the IP, but I still can’t get any data on the site, is it because of that?
what are you getting in the serial monitor?
