Hello, I have an issue with my project.
I need to connect a line chart to my Raspberry but I need to enter a code location and a channel in order to add this widget.
What is the code location and how do I find it ?
Thank you in advance
You cannot add a custom widget to raspberry pi added to cayenne using the link setup.
You will need to use the python library to do so GitHub - myDevicesIoT/Cayenne-MQTT-Python: Python Library for Cayenne MQTT API
Thank you, itβs done
