It is supported, just not officially.
Follow my HowTo…
So my HowTo in a nutshell.
I bought ESP8266-07 modules from AliExpress for a whole $2 each shipped. ESP8266 serial WIFI model ESP 07 Authenticity Guaranteed ESP 07S|Integrated Circuits| - AliExpress
To use them, you must provide a 3.3V supply between VCC and GND, attach the EN pin to VCC, and GPIO15 to GND.
To program, you must pull GPIO0 low, and momenterally put RST low to get into flashing mode.
You should also have an FTDI RS232-3V3 cable or some other USB to Serial converter with 3.3V l…
adam
July 4, 2016, 9:29pm
3
I think he means using it as a shield for the Arduino, which I believe is being worked on right now.
kreggly:
Esp8266
The Blynk library supports it. Don’t know if Cayenne does as I’ve not tried it myself.
It may be as simple as using this line instead in your arduino sketch:
#include “BlynkSimpleShieldEsp8266_HardSer.h”
Do a quick search in this community for esp8266
Bumping this old thread to share that we’ve just provided support in our MQTT Arduino library for using ESP8266 as a shield We’ve done basic testing and works well. Give it a try for your project and let us know how it works out for you !
Steps:
This file has been truncated. show original
