I am monitoring an analog variable using an ESP-12E. I send that value to Cayenne. Then I use an IBoard Pro to control a motor’s speed. This is done automatically using triggers.
I also included a slider to manually adjust the speed of the motor. When the speed is adjusted through triggers (automatically) the slider moves accordingly on the Web platform.
The problem is, when the speed adjusts the slider doesn’t on the Android App. It doesn’t cause any important problems, I am just not able to know the current speed at which the motor is functioning. I have to close the project and open it again on the app in order for the slider to update.
