Arduino MKR wifi 1010 and DHT22 sensor
Does anyone have a working sketch using an Arduino MKR wifi 1010 and DHT22 sensor? I’m just trying to update my Cayenne Dashboard with Humidity and Temperature from this one sensor but I cannot find a working example out there. Needless to say I’m very new to this and any help would be much appreciated.
Thank you,
Mark
for MKR1010 use this Cayenne-MQTT-Arduino/MKR1010.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub and the add the DHT code into it Cayenne-MQTT-Arduino/MKR1010.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub
Thank you, but I have tried that and I cannot find a DHT22 piece of code that will actually show up in the Cayenne dashboard.
sorry, my bad. here is the code for dht Cayenne-MQTT-Arduino/DHT.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub
This is my code, I’m sure it’s very wrong as I’m not a coder but trying to learn. I can get the MKR1010 to connect to wifi but no sensor data is ever sent to Cayenne. Can anyone fix my errors?
-mark FYI the [ ] are showing up as squares for some reason
#include <SPI.h>
#include <CayenneMQTTMKR1010.h>
#include <WiFiNINA.h>
#include <DHT.h>
//Constants
// --SENSOR–
#define DHTPIN 2 // what pin we’re connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define TEMPERATURE_VIRTUAL_CHANNEL 1
#define HUMIDITY_VIRTUAL_CHANNEL 2
#define SECRET_SSID “"
#define SECRET_PASS "
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor.
char ssid = SECRET_SSID;
char pass = SECRET_PASS;
int status = WL_IDLE_STATUS;
char username = “";
char password[] = "
char clientID = “***”;
//Cayenne.begin(username, password, clientID);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println(“Communication with WiFi module failed!”);
// don’t continue
while (true);
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(5000);
// you’re connected now, so print out the data:
Serial.print(“You’re connected to the network”);
printCurrentNet();
printWifiData();
// This function is called at intervals to send temperature sensor data to Cayenne in Celsius.
CAYENNE_OUT(TEMPERATURE_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(TEMPERATURE_VIRTUAL_CHANNEL, dht.readTemperature(), “temp”, “c”);
// This function is called at intervals to send humidity sensor data to Cayenne.
CAYENNE_OUT(HUMIDITY_VIRTUAL_CHANNEL)
Cayenne.virtualWrite(HUMIDITY_VIRTUAL_CHANNEL, dht.readHumidity(), “rel_hum”, “p”);
void printWifiData() {
// print your WiFi shield’s IP address:
IPAddress ip = WiFi.localIP();
Serial.print(“IP Address: “);
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print(“MAC address: “);
Serial.print(mac[5], HEX);
Serial.print(”:”);
Serial.print(mac[4], HEX);
Serial.print(”:”);
Serial.print(mac[3], HEX);
Serial.print(“:”);
Serial.print(mac[2], HEX);
Serial.print(“:”);
Serial.print(mac[1], HEX);
Serial.print(“:”);
Serial.println(mac[0], HEX);
void printCurrentNet() {
// print the SSID of the network you’re attached to:
Serial.print(“SSID: “);
Serial.println(WiFi.SSID());
// print the MAC address of the router you’re attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print(“BSSID: “);
Serial.print(bssid[5], HEX);
Serial.print(”:”);
Serial.print(bssid[4], HEX);
Serial.print(”:”);
Serial.print(bssid[3], HEX);
Serial.print(“:”);
Serial.print(bssid[2], HEX);
Serial.print(“:”);
Serial.print(bssid[1], HEX);
Serial.print(“:”);
Serial.println(bssid[0], HEX);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print(“signal strength (RSSI):”);
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print(“Encryption Type:”);
Serial.println(encryption, HEX);
Serial.println();
just combining the two code is not a difficult task at all.
  This example shows how to connect to Cayenne using an Arduino MKR1010 and send/receive sample data.
  Steps:
  1. Install the Arduino SAMD Boards from the Arduino IDE Boards Manager if you have not already done so.
  2. Install the WiFiNINA library.
  3. Select the MKR1010 board from the Arduino IDE Tools menu.
  4. Set the Cayenne authentication info to match the authentication info from the Dashboard.
  5. Set the network name and password.
  6. Compile and upload the sketch.
  7. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#include <DHT.h>
#define DHTPIN 2
char ssid[] = "ssid";
  dht.begin();
  Cayenne.virtualWrite(TEMPERATURE_VIRTUAL_CHANNEL, dht.readTemperature(), "temp", "c");
  Cayenne.virtualWrite(HUMIDITY_VIRTUAL_CHANNEL, dht.readHumidity(), "rel_hum", "p");
in my case I use mkt 1010 but i can’t enter in loop fuction. I put serial write as first line in loop function but i don’t reach this line . cajenne.begin successfully connect to wifi as I can see il serial out log message but it seem I can’t step out of this function.
Any suggestion?
can you share the code and the serial monitor output with #define CAYENNE_DEBUG added in it.
