Arduino Nano 33 IOT
Ok… Time to put this one to rest i think… i don’t feel like downloading programming software and learning how to create header files. I’ll just use Blynk or another IoT platform.
Thanks for the help… by the way, @farmsensors.iot… Arduino themselves supports your hardware for secure and cloud connection to control and monitor data from the Nano 33 IoT… unless you already knew this and did not like the presentation, etc…
take care all
well, that a good point you have.
@farmsensors.iot let me know if you still facing any issue, will be more than happy to help you learn something on the way.
Hello all, I have one nano 33 Iot , and I’m trying to make a project with Cayenne, I’m using CayenneMQTTUnoWifiRev2.h and I can see in Cayenne dashboard that I have connection.
Problem : it looks that the code in arduino stops in the instruction “Cayenne.begin(username, password, clientID, ssid, wifiPassword);”
The void loop isn’t executed any time, and after 2 or 3 minutes the connection with Cayenne goes off.
( I also didn’t get any data in Cayenne )
Thanks in advance
can you add #define CAYENNE_DEBUG in the code and share the serial monitor output.
Doesn’t do nothing it stops in :
CayenneArduinoMQTTClient.h
72 : CayenneMQTTSubscribe(&_mqttClient, NULL, COMMAND_TOPIC, CAYENNE_ALL_CHANNELS, NULL);
Is the error while compiling? but you mentioned the code gets uploaded.
It compiles and download ok, I have put some log like this :
CAYENNE_LOG(“Connected -1”)
CAYENNE_LOG(“Connected -2”)
and I get the message connected -1
but not the connected -2
You need to first initialize the connection to the server and then subscribe to all the MQTT channels and topics.
Can you use this example
#define CAYENNE_DEBUG       // Uncomment to show debug messages
#include <CayenneMQTTUnoWifiRev2.h>
char ssid[] = "ssid";
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
thats is my code at the moment
ohh, you mean in the CayenneArduinoMQTTClient.h files you have added the debug lines.
correct, to find out where is stopping
can you join in http://slack.mydevices.com/
Has anyone solved this, I feel like I’m getting the exact same issues as everyone above has mentioned, but can’t find any solutions online.
EDIT: To give more context, I have a Nano 33 IoT and can’t get any connection working and I’ve tried all of the example codes and none of them work. I have also reinstalled everything multiple times, but still nothing works. I also get the same issue above, which seems to render the unit useless. If I put any code in the loop it won’t work. I feel like ive tried eveything and it just doesnt work. I have also tested the unit with other code including code to test the Wi-Fi and it is working when I do that…
