Hello, I have a Nano 33 IoT and can’t get any connection working with Cayenne. I’m not 100% clear which example code I’m should to use as the Nano Iot33 isn’t specifically listed on the website, but I’ve ended up trying all the example codes for all shields and none of them have worked for me. If someone could tell me which one to I meant to be using it might help me troubleshoot further. I have been trying with Wifi Shield, Wifi101 and MKR1000.
I have reinstalled everything (SAMD boards, libraries, IDE.) multiple times, but still nothing seems to work.
I’m also not getting anything on serial monitor if I put Serial.print code in void setup or loop.
I have seen some mention that I need to include WifiNINA library with the package, but when I try include that I get errors compiling listed below.
Arduino: 1.8.15 (Mac OS X), Board: "Arduino NANO 33 IoT"
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:35:0,
from /Users/hamshi/Documents/Arduino/libraries/CayenneMQTT/src/CayenneMQTTWiFi101.h:26,
from /Users/hamshi/Documents/Arduino/libraries/CayenneMQTT/src/CayenneMQTTMKR1000.h:23,
from /var/folders/l5/yfdmppr502l54w5nkk6bs_4h0000gn/T/arduino_modified_sketch_73205/MKR1000.ino:21:
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFiClient.h:31:7: error: redefinition of 'class WiFiClient'
class WiFiClient : public Client {
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFi.h:35:0,
from /Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFiNINA.h:23,
from /var/folders/l5/yfdmppr502l54w5nkk6bs_4h0000gn/T/arduino_modified_sketch_73205/MKR1000.ino:1:
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFiClient.h:28:7: note: previous definition of 'class WiFiClient'
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:37:0,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFiServer.h:28:7: error: redefinition of 'class WiFiServer'
class WiFiServer : public Server {
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFi.h:37:0,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFiServer.h:32:7: note: previous definition of 'class WiFiServer'
In file included from /Users/hamshi/Documents/Arduino/libraries/CayenneMQTT/src/CayenneMQTTWiFi101.h:26:0,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:40:17: error: redeclaration of 'WL_NO_SHIELD'
WL_NO_SHIELD = 255,
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFi.h:30:0,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:50:2: note: previous declaration 'wl_status_t WL_NO_SHIELD'
WL_NO_SHIELD = 255,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:41:19: error: redeclaration of 'WL_IDLE_STATUS'
WL_IDLE_STATUS = 0,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:52:9: note: previous declaration 'wl_status_t WL_IDLE_STATUS'
WL_IDLE_STATUS = 0,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:42:2: error: redeclaration of 'WL_NO_SSID_AVAIL'
WL_NO_SSID_AVAIL,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:53:9: note: previous declaration 'wl_status_t WL_NO_SSID_AVAIL'
WL_NO_SSID_AVAIL,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:43:2: error: redeclaration of 'WL_SCAN_COMPLETED'
WL_SCAN_COMPLETED,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:54:9: note: previous declaration 'wl_status_t WL_SCAN_COMPLETED'
WL_SCAN_COMPLETED,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:44:2: error: redeclaration of 'WL_CONNECTED'
WL_CONNECTED,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:55:9: note: previous declaration 'wl_status_t WL_CONNECTED'
WL_CONNECTED,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:45:2: error: redeclaration of 'WL_CONNECT_FAILED'
WL_CONNECT_FAILED,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:56:9: note: previous declaration 'wl_status_t WL_CONNECT_FAILED'
WL_CONNECT_FAILED,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:46:2: error: redeclaration of 'WL_CONNECTION_LOST'
WL_CONNECTION_LOST,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:57:9: note: previous declaration 'wl_status_t WL_CONNECTION_LOST'
WL_CONNECTION_LOST,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:47:2: error: redeclaration of 'WL_DISCONNECTED'
WL_DISCONNECTED,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:58:9: note: previous declaration 'wl_status_t WL_DISCONNECTED'
WL_DISCONNECTED,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:48:2: error: redeclaration of 'WL_AP_LISTENING'
WL_AP_LISTENING,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:59:9: note: previous declaration 'wl_status_t WL_AP_LISTENING'
WL_AP_LISTENING,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:49:2: error: redeclaration of 'WL_AP_CONNECTED'
WL_AP_CONNECTED,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:60:9: note: previous declaration 'wl_status_t WL_AP_CONNECTED'
WL_AP_CONNECTED,
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:50:2: error: redeclaration of 'WL_AP_FAILED'
WL_AP_FAILED,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:61:9: note: previous declaration 'wl_status_t WL_AP_FAILED'
WL_AP_FAILED
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:53:3: error: conflicting declaration 'typedef enum wl_status_t wl_status_t'
} wl_status_t;
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:62:3: note: previous declaration as 'typedef enum wl_status_t wl_status_t'
} wl_status_t;
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:56:6: error: multiple definition of 'enum wl_enc_type'
enum wl_enc_type { /* Values map to 802.11 encryption suites... */
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_definitions.h:65:6: note: previous definition here
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:73:30: error: redeclaration of 'WL_PING_DEST_UNREACHABLE'
WL_PING_DEST_UNREACHABLE = -1,
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFi.h:31:0,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_types.h:51:3: note: previous declaration 'wl_ping_result_t WL_PING_DEST_UNREACHABLE'
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:74:21: error: redeclaration of 'WL_PING_TIMEOUT'
WL_PING_TIMEOUT = -2,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_types.h:52:3: note: previous declaration 'wl_ping_result_t WL_PING_TIMEOUT'
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:75:26: error: redeclaration of 'WL_PING_UNKNOWN_HOST'
WL_PING_UNKNOWN_HOST = -3,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_types.h:53:3: note: previous declaration 'wl_ping_result_t WL_PING_UNKNOWN_HOST'
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:76:19: error: redeclaration of 'WL_PING_ERROR'
WL_PING_ERROR = -4
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_types.h:54:3: note: previous declaration 'wl_ping_result_t WL_PING_ERROR'
WL_PING_ERROR = -4
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:77:3: error: conflicting declaration 'typedef enum wl_ping_result_t wl_ping_result_t'
} wl_ping_result_t;
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/utility/wl_types.h:55:3: note: previous declaration as 'typedef enum wl_ping_result_t wl_ping_result_t'
} wl_ping_result_t;
/Users/hamshi/Documents/Arduino/libraries/WiFi101/src/WiFi101.h:79:7: error: redefinition of 'class WiFiClass'
class WiFiClass
In file included from /Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFiNINA.h:23:0,
/Users/hamshi/Documents/Arduino/libraries/WiFiNINA/src/WiFi.h:42:7: note: previous definition of 'class WiFiClass'
class WiFiClass
exit status 1
Error compiling for board Arduino NANO 33 IoT.
"Show verbose output during compilation"
option enabled in File -> Preferences.
