After I change to 115200, and also change the code of the cayenne code, the results seems different.
10:15:41.201 → [1529] ESP is not responding
10:15:43.740 → [4040] ESP is not responding
10:15:46.242 → [6550] ESP is not responding
10:15:49.090 → [9392] Failed to enable MUX
10:15:52.117 → [12421] Connected to WiFi
10:15:52.117 → [12422] Connecting to mqtt.mydevices.com:1883
10:15:53.545 → [13870] Connected
10:15:54.486 → [14795] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
10:15:59.493 → [19807] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
10:16:04.494 → [24819] Publish: topic 7, channel 65534, value 16000000, subkey , key
10:16:09.502 → [29833] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
10:16:14.548 → [34845] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
10:16:14.583 → [34906] Publish: topic 1, channel 1, value 0, subkey , key
10:16:24.556 → [44880] Connection ok
10:16:29.599 → [49910] Publish: topic 1, channel 1, value 0, subkey , key
10:16:34.606 → [54904] Connection ok
10:16:44.628 → [64934] Publish: topic 1, channel 1, value 0, subkey , key
10:16:49.969 → [70287] Connection ok
10:17:09.513 → [89838] Disconnected
10:17:09.513 → [89838] Connecting to mqtt.mydevices.com:1883
10:17:11.528 → [91839] Connected
10:17:12.640 → [92965] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
10:17:17.676 → [97977] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
10:17:22.663 → [102989] Publish: topic 7, channel 65534, value 16000000, subkey , key
10:17:27.675 → [108002] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
10:17:32.711 → [113014] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
10:17:32.746 → [113045] Publish: topic 1, channel 1, value 0, subkey , key
10:17:33.999 → [114292] Connection ok
10:17:44.002 → [124320] Connection ok
10:17:47.743 → [128055] Publish: topic 1, channel 1, value 0, subkey , key
10:17:57.796 → [138091] Connection ok
10:18:02.736 → [143062] Publish: topic 1, channel 1, value 0, subkey , key
10:18:07.813 → [148118] Connection ok
10:18:17.769 → [158070] Publish: topic 1, channel 1, value 0, subkey , key
10:18:18.919 → [159223] Connection ok
10:18:28.903 → [169224] Connection ok
10:18:32.763 → [173078] Publish: topic 1, channel 1, value 0, subkey , key
10:18:38.923 → [179238] Connection ok
10:18:47.812 → [188092] Publish: topic 1, channel 1, value 0, subkey , key
10:18:52.791 → [193114] Connection ok
10:19:02.789 → [203114] Publish: topic 1, channel 1, value 0, subkey , key
10:19:07.823 → [208136] Connection ok
10:19:23.099 → [223398] Disconnected
10:19:23.099 → [223398] Connecting to mqtt.mydevices.com:1883
10:19:25.169 → [225478] Connected
10:19:26.415 → [226718] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
10:19:31.411 → [231731] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
10:19:36.438 → [236743] Publish: topic 7, channel 65534, value 16000000, subkey , key
10:19:41.436 → [241756] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
10:19:46.468 → [246768] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
10:19:46.503 → [246799] Publish: topic 1, channel 1, value 0, subkey , key
10:19:47.545 → [247835] Connection ok
10:19:57.560 → [257865] Connection ok
10:20:01.516 → [261810] Publish: topic 1, channel 1, value 0, subkey , key
10:20:07.556 → [267872] Connection ok
10:20:16.521 → [276816] Publish: topic 1, channel 1, value 0, subkey , key
10:20:21.910 → [282218] Connection ok
10:20:41.464 → [301771] Disconnected
10:20:41.464 → [301771] Connecting to mqtt.mydevices.com:1883
10:20:43.045 → [303353] Connected
10:20:44.076 → [304388] Publish: topic 4, channel 65534, value Arduino Uno, subkey , key
10:20:49.110 → [309400] Publish: topic 6, channel 65534, value ATmega328P, subkey , key
10:20:54.114 → [314412] Publish: topic 7, channel 65534, value 16000000, subkey , key
10:20:59.117 → [319425] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
10:21:04.134 → [324438] Publish: topic 8, channel 65534, value ESP8266Shield, subkey , key
10:21:04.166 → [324469] Publish: topic 1, channel 1, value 0, subkey , key
10:21:05.122 → [325412] Connection ok
10:21:15.131 → [335440] Connection ok
10:21:19.186 → [339476] Publish: topic 1, channel 1, value 0, subkey , key
10:21:25.130 → [345444] Connection ok
10:21:34.181 → [354480] Publish: topic 1, channel 1, value 0, subkey , key
But on the cayenne dashboard, it still goes offline after a while, and get connected again, and offline…
still no data uploaded to cayanne. or maybe something with the the widget I set… hmm
