Hello
I just discover the Cayenne tool and give it a try.
Pretty nice, but to my surprise ( i’m un experimented) it use nearly 50% of my program storage space. Project is not finished and I’m using 90% of the available space.
Sketch uses 29074 bytes (90%) of program storage space. Maximum is 32256 bytes.
Global variables use 1445 bytes (70%) of dynamic memory, leaving 603 bytes for local variables. Maximum is 2048 bytes.
Any trick to reduce it?
I understand that an easy solution is to get another processor, but for the moment, this is the one that I got.
Martin
My amateur code… I’m a newby
#include “HX711.h”
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x21, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
char username = “2d0bc3f0-2390-11ea-a38a-d57172a4b4d4”;
char password = “0ec6d172b2ad6324253cef027df4e87c1faf32c7”;
char clientID = “7e949c00-2391-11ea-8221-599f77add412”;
int calibration = 15000;
#define calibration_factor calibration //This value is obtained using the SparkFun_HX711_Calibration sketch 5VDC
//#define calibration_factor 15350.0 //This value is obtained using the SparkFun_HX711_Calibration sketch 3.3 VDZ
#define DOUT 3
#define CLK 2
byte _data; //KeySwitch
byte aButton;//KeySwitch
const int interval = 1000;
long Poids;
HX711 scale;
//Key SwitchWire.begin();
Wire.beginTransmission(0x20);
Wire.write(0xff); // put a high level on pins
Wire.endTransmission();
// Serial.println(“HX711 scale demo”);
scale.begin(DOUT, CLK);
scale.set_scale (calibration); //(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
lcd.init();
lcd.setCursor(0, 0);
lcd.print("Balance: ");
//Serial.println(“Readings:”);
int Button();
aButton = Button();
if (aButton == 1) {
lcd.setCursor(0, 1);
lcd.print(“TARE”);
scale.tare();
// delay(1000);
lcd.print(" ");
//if (aButton == 3) {Serial.println(aButton);}
//if (aButton == 4) {Serial.println(aButton);}
//if (aButton == 5) {
if (aButton == 6) {
(calibration = calibration + 100);
//Call reset
if (aButton == 7) {
lcd.setCursor(0, 2);
lcd.print(“Reset”);
//delay(1000);
softReset();
aButton == 10;
//____________________
//Serial.print(“Reading: “);
//Serial.print(scale.get_units(), 2); //scale.get_units() returns a float
//Serial.print(” kg”); //You can change this to kg but you’ll need to refactor the calibration_factor
// Serial.println();
lcd.setCursor(0, 3);
lcd.print(scale.get_units(10), 2);
lcd.print(" kg ");
//Function______________________________________________
byte Button() {
byte data;
const int debounce = 225;
byte aButton = (0);
Wire.begin();
Wire.requestFrom(0x20, 1);
if (Wire.available()) {
_data = Wire.read();
if (_data < 255) {
delay(debounce);
if (_data == 254) aButton_ = 1;
if (_data == 251) aButton_ = 3;
if (_data == 247) aButton_ = 4;
if (_data == 239) aButton_ = 5;
if (_data == 223) aButton_ = 6;
if (_data == 191) aButton_ = 7;
return aButton_ ;
//Reset
void softReset() {
asm volatile (" jmp 0");
