I have successfully uploaded the example codes of the WIFI shield provided by cayenne but it doesn’t show on cayenne automatically, it only shows ‘‘Waiting for board to connect…’’ and there is nothing in the serial monitor! Anyone who can help me? SOS!
Can you share the code you are using and which wifi shield you are using?
sure! Thanks for your help!
I selected the arduino uno wifi shield and have installed the CayenneMQTT Library.
These are my codes as follows:
This example shows how to connect to Cayenne using a WiFi shield and send/receive sample data.
Steps:
- Set the network name and password.
- Compile and upload the sketch.
- A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
#include <CayenneMQTTWiFi.h>
char ssid = “TELUSxxxx”;
char wifiPassword = “xxxxxxxxxxxxxxxxxxx”;
char username = “3ef26550-5bd8-11ed-bf0a-bb4ba43bd3f6”;
char password = “23a522a0ce46c0ddab9cf95bad7db510a16bdb4f”;
char clientID = “602e7b10-96fb-11ed-8d53-d7cd1025126a”;
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
I also got some warning like these after I compiled the codes:
