Device & model you are using (Ex: Arduino Uno with Manual Connection using USB)
What dashboard are you using? (Web)
I have connected my Arduino Uno using manual connection but my board is not connecting and dashboard is not displaying
can you share the code you are using?
Steps:
char ssid[] = "ssid";
char username[] = "----";
char password[] = "";
char clientID[] = "----";
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
i used usb connector and esp8266 wifi modules but the board is not getting connected.
this code is for arduino mega which has extra hardware serial. though you can use it for arduino uno which is quite unstable.
you need to connect the esp8266 to uno TX and RX pins throught a voltage divider. try this code:
Steps:
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial hardware serial pins available on the UNO.
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char clientID[] = "";
delay(10);
delay(10);
i have replaced the code sent by you and i have installed the cayenne libraries still, “Waiting for the board to connect” is the only thing i can see…
make sure the esp8266 baud rate is set to 9600.
yeah everything was set up to the mark but still no connection
can you share the output of your serial monitor?
This is the status of the serial monitor.
this is the thing not getting connected
do you have an arduino mega or any other esp8266 development board like nodemcu or wemos. As i said earlier it is quite unstable on arduino uno and difficult to debug.
the output i get is
can you try setting the esp8266 baud rate to 115200 and give it a try
Hii i tried with baudrate 115200 but no use can i connect my arduino device using usb port A/B .![download](https://global.discourse-cdn.com/business5/uploads/mydevices/original/2X/c/cf7166c59fa289ac03c5ec8054962ba1b8aff91c.jpeg)
