i just made a test setup with your code (with no periperials) and only change i made was send random data to cayenne:
if (millis() - lastMillis > 15000) {
lastMillis = millis();
x++;
Cayenne.virtualWrite(volumeChannel, x);
Cayenne.virtualWrite(poursChannel, x);
if you say the while (calibrationStart == true){ is not executed by pressing the button, then it worked for me.
here is the entire code:
//include I2C LCD Libraries
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
//Create I2C Object w/address, columns, and rows
LiquidCrystal_I2C lcd(0x27, 20, 4);
int x;
//include HX711 Library
#include "HX711.h"
char username[] = "";
char password[] = "";
char clientID[] = "";
//Include Adafruit Neopixel Library and define Pin# for gauge
#include <Adafruit_NeoPixel.h>
#define PIN 6
//Declare Pins for the Mass ISR and a Mass Global
const byte ISRSwitch = 2;//Turns on LEDs and must be engaged for calibration ISR
const byte ISRButton = 3;//Will initiate calibration ISR if ISRSwitch == 0
const byte ISRButtonLED = 4;//Turns on with ISRSwitch
const byte ISRSwitchLED = 5;//Turns on with ISRSwitch
//Create State Flags for ISRs
volatile boolean calibrationStart = false;//changes with IRSButton
volatile boolean notify = false;//changes with ISRButton
volatile boolean switchON = false;//changes with ISRSwitch
//Declare buttons and dials for calibration sequence
const byte next = 7;
const byte setButton = 8;
const byte dialPot = A0;
//Declare state flags for calibration sequence
boolean setEmptyMass = false;
boolean setFullVolume = false;
boolean setFullMass = false;
boolean setColorOne = false;
boolean setColorTwo = false;
boolean setColorThree = false;
//Default values for calibration variables
float emptyMass = 16.0;//Default mass of empty container in lbs
float fullVolume = 660.0;//default volume of full container in fluid ounces
float pourVolume = 12.0;
float fullMass;//Global variable to be changed in Calibration
//Cayenne credentials
//Define Cayenne Channels
const byte volumeChannel = 0;//shows volume in keg
const byte poursChannel = 1;//shows how many pours remain
//Set HX711 Pins for the scale
#define DOUT 11
#define CLK 12
//Create HX711 Object
HX711 scale(DOUT, CLK);
//Set calibration factor for scale
#define calibration_factor -10080
#define zero_factor 1052867
//Create buffers for variable readings and LCD string printouts
char line1 [21];
char lg_str [6];//handles liquidVolume
char line2 [21];//reports liquidVolume string
char sm_str [5];//handles poursRemaining
//Name of Current Beer on Tap and Brewery
char myBeer[] = "Saturn in Scorpio";
char myBrewery[] = "Foreign Objects";
//Create Adafruit Neopixel Object with colors
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
uint32_t red = strip.Color(255, 0, 0);
uint32_t orange = strip.Color(255, 140, 0);
uint32_t yellow = strip.Color(255, 255, 0);
uint32_t green = strip.Color(0, 128, 0);
uint32_t blue = strip.Color(0, 0, 255);
uint32_t navyBlue = strip.Color(0, 0, 128);
uint32_t purple = strip.Color(128, 0, 128);
uint32_t white = strip.Color(127, 127, 127);
uint32_t off = strip.Color(0, 0, 0);
uint32_t colorOne = red;
uint32_t colorTwo = blue;
uint32_t colorThree = white;
//Variables for Cayenne call
unsigned long lastMillis = 0;
float liquidVolume;
float poursRemaining;
//Open Serial Communication
Cayenne.begin(username, password, clientID, 9600);
//Create the ISRs and pinModes for ISRSwitch and ISRButton
digitalWrite(ISRSwitch, HIGH);
digitalWrite(ISRButton, HIGH);
pinMode(ISRSwitch, INPUT_PULLUP);
pinMode(ISRButton, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(ISRSwitch), LEDStateISR, FALLING);
attachInterrupt(digitalPinToInterrupt(ISRButton), CalibrationISR, FALLING);
pinMode(ISRSwitchLED, OUTPUT);
pinMode(ISRButtonLED, OUTPUT);
//Declare pinModes for calibration buttons
pinMode(setButton, INPUT_PULLUP);
pinMode(next, INPUT_PULLUP);
//Initiate Neopixel Object and clear the pixels
strip.begin();
strip.show();
//Initialize your LCD object as being a 16 column, 2 row LCD
lcd.begin();
for (int i = 0; i < 3; i++) //flash the LCD 3 times to test upon Power On
lcd.backlight();
delay(250);
lcd.noBacklight();
delay(250);
lcd.backlight(); //set backlight as ON after 3 flashes
//Introduction prints name of beer on LCD row 1 and Brewery to row 2
lcd.setCursor(0, 0);
lcd.print(myBeer);
lcd.setCursor(0, 1);
lcd.print(myBrewery);
//Turn on the Scale
scale.set_scale(calibration_factor);
scale.set_offset(zero_factor);
//Begins calibration sequence if ISR has been run
while (calibrationStart == true) {
while (notify == true) {
notify = false;//reset notify flag
setEmptyMass = true;//raise emptyMass flag
lcd.clear();
lcd.print("Entering Calibration");
lcd.print("Lower Red Toggle");
lcd.setCursor(0, 2);
lcd.print("Directions to Follow");
delay(5000);
lcd.clear();
while (setEmptyMass == true) {
//lcd.clear();
lcd.print("Put empty container");
lcd.print("on the scale and...");
lcd.print("To SET Press Blue");
lcd.setCursor(0, 3);
lcd.print("To SKIP Press Green");
if (digitalRead(setButton) == 0) {
setFullVolume = true;
emptyMass = scale.get_units();
lcd.clear();
lcd.print("Empty Mass is Set!");
dtostrf(emptyMass, 4, 1, sm_str);
sprintf(line1, "Empty Mass: %s lbs", sm_str);
lcd.print(line1);
delay(3000);
lcd.clear();
if (digitalRead(next) == 0) {
lcd.clear();
lcd.print(line1);
delay(3000);
lcd.clear();
while (setFullVolume == true) {
//lcd.clear();
float localPot = analogRead(dialPot);//read the volume calibration dial
float localVolume = map(localPot, 0, 1023, 320, 1280); //convert reading to ounces between 2.5 and 10 gallons
localVolume = constrain(localVolume, 320, 1280);//restrict the reading to an acceptable range
lcd.print("Adjust Vol with Dial");
dtostrf(localVolume, 4, 0, sm_str);
sprintf(line1, "Total Vol: %s oz", sm_str);
lcd.print(line1);
setColorOne = true;
fullVolume = localVolume;
lcd.clear();
lcd.print("Full Volume is Set!");
dtostrf(fullVolume, 4, 0, sm_str);
lcd.print(line1);
delay(3000);
lcd.clear();
setColorOne = true;
lcd.clear();
lcd.print(line1);
delay(3000);
lcd.clear();
while (setColorOne == true) {
char colorPrintOne[] = "red";
char* color = choosePrint();
uint32_t localColor = chooseColor(color);
printColor(localColor);
lcd.print("Adjust Color w/ Dial");
sprintf(line1, "1st Color: %s ", color);
lcd.print(line1);
setColorTwo = true;
colorOne = localColor;
lcd.clear();
lcd.print("Color One is Set!");
lcd.print(line1);
printColor(colorOne);
delay(3000);
pixelsOff();
lcd.clear();
setColorTwo = true;
lcd.clear();
sprintf(line1, "1st Color: %s ", colorPrintOne);
lcd.print(line1);
delay(3000);
pixelsOff();
lcd.clear();
while (setColorTwo == true) {
char colorPrintTwo[] = "blue";
sprintf(line1, "2nd Color: %s ", color);
lcd.print(line1);
setColorThree = true;
colorTwo = localColor;
lcd.clear();
lcd.print("Color Two is Set!");
lcd.print(line1);
printColor(colorTwo);
delay(3000);
pixelsOff();
lcd.clear();
lcd.clear();
sprintf(line1, "2nd Color: %s ", colorPrintTwo);
lcd.print(line1);
delay(3000);
pixelsOff();
lcd.clear();
while (setColorThree == true) {
char colorPrintThree[] = "white";
sprintf(line1, "3rd Color: %s ", color);
lcd.print(line1);
setFullMass = true;
colorThree = localColor;
lcd.clear();
lcd.print("Color Three is Set!");
lcd.print(line1);
printColor(colorThree);
delay(3000);
pixelsOff();
lcd.clear();
setFullMass = true;
lcd.clear();
sprintf(line1, "3rd Color: %s ", colorPrintThree);
lcd.print(line1);
delay(3000);
pixelsOff();
lcd.clear();
while (setFullMass == true) {
//lcd.clear();
fullMass = scale.get_units();
lcd.print("Set Total Mass");
dtostrf(fullMass, 5, 1, lg_str);
sprintf(line1, "Full Mass: %s lbs", lg_str);
lcd.print(line1);
lcd.print("DO NOT Press Green");
lcd.clear();
lcd.print("Full Mass is Set!");
lcd.print(line1);
delay(3000);
lcd.clear();
lcd.print("Calibration Over!");
lcd.print("Tasty IPAs Await.");
lcd.print("Enjoy your beer...");
lcd.print("LET'S GO RANGERS!");
delay(3000);
switchON = false;
digitalWrite(ISRButtonLED, switchON);
digitalWrite(ISRSwitchLED, switchON);
lcd.clear();
lcd.print(myBeer);
kegTester();
x++;
void kegTester (void)
//Grabs current mass of container
float currentMass = scale.get_units();
float liquidMassLbs = currentMass - emptyMass;//weight in lbs of beer only
float liquidMassOunces = liquidMassLbs * 16.0; // weight of beer in ounces
noInterrupts();//Block ISR
float fullMassLocal = fullMass;
float fullLiquidMassOunces = ((fullMassLocal - emptyMass) * 16.0);
interrupts();//reenable ISR
//convert the mass of liquid into fluid ounces
liquidVolume = map (liquidMassOunces, 0, fullLiquidMassOunces, 0, fullVolume);
liquidVolume = constrain(liquidVolume, 0, fullVolume);//keeps data in acceptable range
//calculate the # of pours in container based on a tulip glass
poursRemaining = liquidVolume / pourVolume;
//Prints total ounces remaining to LCD
dtostrf(liquidVolume, 5, 1, lg_str);
sprintf(line1, "Keg Level: %s oz", lg_str);
lcd.print(line1);
//Prints Beers Remaining to LCD
dtostrf(poursRemaining, 4, 1, sm_str);
sprintf(line2, "Pours Left: %s", sm_str);
lcd.print(line2);
//Convert volume of liquid to the 60 pixles on the strip
int pixels = map(liquidVolume, 0, fullVolume, 0, 59);
pixels = constrain(pixels, 0, 59);
//calls function to light the strip and passes the mapped pixels
LightShow(pixels);
void LightShow(int pixels) {
//Clears all pixels
for (int b = 0; b <= 60; b++) {
strip.setPixelColor(b, off);
strip.show();
//Lights the first 20 pixels to red based on volume
if (pixels < 20) {
for (int i = 0; i <= pixels; i++) {
strip.setPixelColor(i, colorOne);
strip.show();
//Lights first 20 to red and second 20 to blue
if (pixels >= 20 && pixels < 40) {
for (int i = 0; i < 20; i++) {
for (int j = 20; j <= pixels; j++) {
strip.setPixelColor(j, colorTwo);
strip.show();
//Lights first 20 to red, second 20 to blue, third to white
if (pixels >= 40) {
for (int j = 20; j <= 39; j++) {
for (int k = 40; k <= pixels; k++) {
strip.setPixelColor(k, colorThree);
strip.show();//writes the colors to the strip
//ISR to Calibrate New Full Mass Upon Button Press
void CalibrationISR (void) {
if (switchON == true) {
//ISR only executes if Trigger is flipped
//switchON == false;
calibrationStart = true;
notify = true;
void LEDStateISR (void) {
switchON = true;
char* choosePrint (void) {
int localPot = analogRead(dialPot);//read the calibration dial
int colorSelect = map(localPot, 0, 900, 1, 8); //convert reading to 1-8 for switch cases
colorSelect = constrain(colorSelect, 1, 8);//restrict the reading to an acceptable range
char* colorPrint;
switch (colorSelect) {
case 1:
colorPrint = "red";
break;
case 2:
//localOne = orange;
colorPrint = "orange";
break;
case 3:
//localOne = yellow;
colorPrint = "yellow";
break;
case 4:
//localOne = green;
colorPrint = "green";
break;
case 5:
//localOne = blue;
colorPrint = "blue";
break;
case 6:
//localOne = navyBlue;
colorPrint = "navy";
break;
case 7:
//localOne = purple;
colorPrint = "purple";
break;
case 8:
//localOne = white;
colorPrint = "white";
break;
return colorPrint;
uint32_t chooseColor(String colorPrint) {
uint32_t color;
if (colorPrint == "red") {
color = red;
else if (colorPrint == "orange") {
color = orange;
else if (colorPrint == "yellow") {
color = yellow;
else if (colorPrint == "green") {
color = green;
else if (colorPrint == "blue") {
color = blue;
else if (colorPrint == "navy") {
color = navyBlue;
else if (colorPrint == "purple") {
color = purple;
else if (colorPrint == "white") {
color = white;
return color;
void printColor (uint32_t color) {
strip.setPixelColor(b, color);
strip.show();
void pixelsOff (void) {
strip.show();
i used arduino mega as the sketch was quite big for uno
