Cayenne.loop () function
Hi everyone.
I design an alarm system for a home.
The core of the system is a bunch of arduino mega
  • GSM modem. Working with the server via the Internet does not cause problems. The problem is that there is no landline internet in the house. And the quality of the GSM internet (GPRS) is not the best. Therefore, I would like to have a backup control channel, for example SMS. Only when the system is running, the Cayenne.loop () function; takes all the resources of the system “on itself” without allowing other program components to run. How can you get around this?
sorry, there is no offline mode supported in cayenne. The cayenne loop checks continuously for the connection hence you cannot add an external code when there is no internet connection.
There is an internet connection. How to make sure that other codes are executed in the loop in addition to the Cayenne.loop () function?
if there is a connection then the rest of the code should work.
But it doesn’t work that way. The function takes 24 seconds. processor time, freeing it to execute other codes for 1 second.
24 sec. that is too much. can you share the code you are using.
Yes of course. How to put a listing of the program - the file .ino is not attached.
#define CAYENNE_DEBUG
#define TINY_GSM_MODEM_A6
#define SerialMon Serial
#define TINY_GSM_RX_BUFFER 512
#define gsmSerial Serial1
#define TINY_GSM_DEBUG SerialMon
#define GSM_PIN ""
#include <CayenneMQTTGSM.h>
#include <CayenneMQTTGSMClient.h>
#define REMOTEXY_MODE__HARDSERIAL
#include <RemoteXY.h>
#define REMOTEXY_SERIAL Serial2
#define REMOTEXY_SERIAL_SPEED 115200
#include <Wire.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 7
DallasTemperature ds(&oneWire);
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
Adafruit_BME280 bme;
#include <iarduino_RTC.h>
iarduino_RTC time(RTC_DS3231);
#include <UTFT.h>
UTFT myGLCD(TFT32MEGA_2, 38, 39, 40, 41);
#include <URTouch.h>
URTouch  myTouch(52, 53, 51, 50, 44);
#include "GyverWDT.h"
extern uint8_t SevenSegNumFont[];
extern uint8_t Grotesk16x32[];
extern uint8_t Grotesk24x48[];
extern uint8_t Arial_round_16x24[];
double tempH, presH, humH, tempL, tempR, tempOut  = 0.0;
byte qty;
uint8_t D, d, M, Y ;
uint8_t h, m, s ;
unsigned char L, H, B, F = 0;
int x, y;
char incomingByte;
String inputString;
unsigned char N0, N1, N2, N3, K, Status, Signal, State = 0;
unsigned char led_1_r;
unsigned char led_1_g;
unsigned char led_2_r;
unsigned char led_2_g;
unsigned char led_3_r;
unsigned char led_3_g;
unsigned char led_4_r;
unsigned char led_4_g;
unsigned char switch_1;
unsigned char switch_2;
unsigned char switch_3;
unsigned char switch_4;
#define Liht 2
#define Heater 3
#define Boiler 4
#define Fridge 5
#define Power 6
String Message;
char     SMStxt[161];
char     SMSnum[ 13];
char     SMStim[ 18];
uint16_t SMSlongID;
uint8_t  SMSlongSUM;
uint8_t  SMSlongNUM;
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255, 4, 0, 41, 0, 12, 1, 10, 178, 1,
  65, 38, 52, 89, 9, 9, 2, 1, 2, 88,
  22, 11, 79, 26, 135, 36, 79, 78, 0, 79,
  70, 70, 0, 2, 1, 2, 62, 22, 11, 78,
  26, 135, 37, 79, 78, 0, 79, 70, 70, 0,
  2, 1, 2, 75, 22, 11, 78, 26, 135, 36,
  79, 78, 0, 79, 70, 70, 0, 2, 1, 2,
  49, 22, 11, 78, 26, 135, 36, 79, 78, 0,
  79, 70, 70, 0, 65, 38, 52, 63, 9, 9,
  65, 38, 52, 77, 9, 9, 67, 1, 43, 15,
  26, 9, 31, 26, 11, 67, 1, 43, 24, 26,
  9, 31, 26, 11, 129, 0, 1, 27, 22, 6,
  31, 72, 85, 77, 44, 32, 37, 0, 129, 0,
  1, 18, 22, 6, 31, 84, 77, 80, 44, 32,
  194, 176, 67, 0, 65, 38, 52, 50, 9, 9,
  129, 0, 1, 36, 38, 6, 31, 80, 82, 69,
  83, 44, 32, 109, 109, 72, 71, 0, 67, 1,
  43, 34, 22, 9, 31, 26, 11, 129, 0, 26,
  52, 13, 6, 31, 76, 73, 72, 84, 0, 129,
  0, 26, 65, 24, 6, 31, 72, 69, 65, 84,
  69, 82, 0, 129, 0, 26, 78, 23, 6, 31,
  66, 79, 73, 76, 69, 82, 0, 129, 0, 26,
  91, 23, 6, 31, 70, 82, 73, 68, 71, 69,
  0, 129, 0, 2, 6, 31, 6, 31, 79, 85,
  84, 68, 79, 79, 82, 0, 129, 0, 35, 6,
  26, 6, 31, 67, 76, 73, 77, 65, 84, 69,
  0, 130, 2, 0, 13, 63, 3, 31, 130, 2,
  0, 43, 64, 3, 31
struct {
  uint8_t switch_4;
  uint8_t switch_2;
  uint8_t switch_3;
  uint8_t switch_1;
  uint8_t led_4_r;
  uint8_t led_4_g;
  uint8_t led_2_r;
  uint8_t led_2_g;
  uint8_t led_3_r;
  uint8_t led_3_g;
  char text_1[11];
  char text_2[11];
  uint8_t led_1_r;
  uint8_t led_1_g;
  char text_3[11];
  uint8_t connect_flag;
} RemoteXY;
#pragma pack(pop)
char apn[] = "internet";
char gprsLogin[] = "gdata";
char gprsPassword[] = "gdata";
char pin[] = "";
char username[] = "45df2b50-7020-11eb-b767-3f1a8f1211ba";
char password[] = "9d0202fe177ad42e667cdd2e26389ba1cf7ff7ac";
char clientID[] = "11161260-734c-11eb-a2e4-b32ea624e442";
  RemoteXY_Init ();
  Serial.begin(115200);
  Wire.begin();
  time.begin();
  bme.begin(0x76);
  ds.begin();
  qty = ds.getDeviceCount();
  myGLCD.InitLCD(LANDSCAPE);
  myTouch.InitTouch(LANDSCAPE);
  myTouch.setPrecision(PREC_MEDIUM);
  pinMode(Power, OUTPUT);
  digitalWrite(Power, LOW);
  delay (2000);
  digitalWrite(Power, HIGH);
  delay (3000);
  pinMode(Fridge, OUTPUT);
  digitalWrite(Fridge, HIGH);
  pinMode(Liht, OUTPUT);
  digitalWrite(Liht, HIGH);
  pinMode(Heater, OUTPUT);
  digitalWrite(Heater, HIGH);
  pinMode(Boiler, OUTPUT);
  digitalWrite(Boiler, HIGH);
  TinyGsmAutoBaud(gsmSerial);
  Cayenne.begin(username, password, clientID, gsmSerial, apn, gprsLogin, gprsPassword, pin);
  myGLCD.fillScr(VGA_BLUE);
  myGLCD.setFont(Arial_round_16x24);
  myGLCD.setBackColor(VGA_BLUE);
  myGLCD.setColor(VGA_YELLOW);
  myGLCD.print("Initialization, please wait...", 0, 5);
  delay(5000);
  myGLCD.clrScr();
void(* resetFunc) (void) = 0;
  Watchdog.enable(RESET_MODE, WDT_PRESCALER_1024);
  RemoteXY_Handler ();
  Info();
  Infoext();
  while (myTouch.dataAvailable())
    myTouch.read();
    x = myTouch.getX();
    y = myTouch.getY();
    if ((x >= 0 && x <= 50) && (y >= 0 && y <= 50))
      MainMenu ();
  State = RemoteXY_isConnected();
  if (State == 1)
    Bluetooth ();
  Watchdog.reset();
void Bluetooth ()
  Watchdog.disable ();
  myGLCD.setColor(VGA_RED);
  myGLCD.fillRoundRect (0, 0, 480, 160);
  myGLCD.setBackColor(VGA_RED);
  myGLCD.setColor(VGA_WHITE);
  myGLCD.print ("DEVICE UNDER", CENTER, 5);
  myGLCD.print ("BLUETOOTH CONTROL!!!", CENTER, 35);
  myGLCD.print ("FOR RETURN TO MANUAL CONTROL", CENTER, 65);
  myGLCD.print ("TURN OFF THE BLUETOOTH", CENTER, 95);
  myGLCD.print ("CONTROL DEVICE!", CENTER, 125);
Bluetooth:
  tempH = bme.readTemperature();
  presH = bme.readPressure() * 0.00750062;
  humH = bme.readHumidity();
  Infoext ();
  if (State == 1)
    if (RemoteXY.switch_1 != 0)
      digitalWrite(Liht, LOW);
      RemoteXY.led_1_r = 0;
      RemoteXY.led_1_g = 255;
    else
      RemoteXY.led_1_r = 255;
      RemoteXY.led_1_g = 0;
    if (RemoteXY.switch_2 != 0)
      digitalWrite(Heater, LOW);
      RemoteXY.led_2_r = 0;
      RemoteXY.led_2_g = 255;
    else
      RemoteXY.led_2_r = 255;
      RemoteXY.led_2_g = 0;
    if (RemoteXY.switch_3 != 0)
      digitalWrite(Boiler, LOW);
      RemoteXY.led_3_r = 0;
      RemoteXY.led_3_g = 255;
    else
      RemoteXY.led_3_r = 255;
      RemoteXY.led_3_g = 0;
    if (RemoteXY.switch_4 != 0)
      digitalWrite(Fridge, LOW);
      RemoteXY.led_4_r = 0;
      RemoteXY.led_4_g = 255;
    else
      RemoteXY.led_4_r = 255;
      RemoteXY.led_4_g = 0;
    dtostrf( tempH, 0, 0, RemoteXY.text_1);
    dtostrf( humH, 0, 0, RemoteXY.text_2);
    dtostrf( presH, 0, 0, RemoteXY.text_3);
    goto Bluetooth;
  if (State == 0)
    myGLCD.clrScr();
void Info()
  myGLCD.setBackColor(VGA_BLACK);
  time.gettime();
  h = time.Hours;
  m = time.minutes;
  s = time.seconds;
  d = time.day;
  M = time.month;
  Y = time.year;
  myGLCD.setFont(SevenSegNumFont);
  if (h <= 9)
    myGLCD.printNumI(0, 240, 5);
    myGLCD.printNumI(h, 270, 5);
  if (h >= 10)
    myGLCD.printNumI(h, 235, 5);
  if (m <= 9)
    myGLCD.printNumI(0, 325, 5);
    myGLCD.printNumI(m, 355, 5);
  if (m >= 10)
    myGLCD.printNumI(m, 325, 5);
  if (s <= 9)
    myGLCD.printNumI(0, 410, 5);
    myGLCD.printNumI(s, 440, 5);
  if (s >= 10)
    myGLCD.printNumI(s, 410, 5);
  if (d <= 9)
    myGLCD.printNumI(0, 235, 65);
    myGLCD.printNumI(d, 265, 65);
  if (d >= 10)
    myGLCD.printNumI(d, 235, 65);
  if (M <= 9)
    myGLCD.printNumI(0, 325, 65);
    myGLCD.printNumI(M, 355, 65);
  if (M >= 10)
    myGLCD.printNumI(M, 325, 65);
  myGLCD.printNumI (Y, 410, 65);
  byte daY = d;
  byte month =  M;
  unsigned int Year = Y;
  byte a = f_div((14 - month), 12);
  unsigned int Y = Year - a;
  byte m = month + 12 * a - 2;
  unsigned int Y4 = f_div(Y, 4);
  byte Y100 = f_div(Y, 100);
  byte Y400 = f_div(Y, 400);
  byte X = f_div(31 * m, 12);
  byte D = ((daY + Y + Y4 - Y100 + Y400 + X) % 7);
  if (D == 1)
    myGLCD.setFont(Grotesk16x32);
    myGLCD.print ("MONDAY", 300, 125);
  if (D == 2)
    myGLCD.print ("TUESDAY", 298, 125);
  if (D == 3)
    myGLCD.print ("WEDNESDAY", 290, 125);
  if (D == 4)
    myGLCD.print ("THURSDAY", 298, 125);
  if (D == 5)
    myGLCD.print ("FRIDAY", 298, 125);
  if (D == 6)
    myGLCD.print ("SATURDAY", 300, 125);
  if (D == 7)
    myGLCD.print ("SUNDAY", 300, 125);
  myGLCD.setFont(Grotesk24x48);
  myGLCD.print (":", 300, 2);
  myGLCD.print (":", 388, 2);
  myGLCD.print ("/", 298, 65);
  myGLCD.print ("/", 388, 65);
  myGLCD.fillRoundRect (0, 160, 480, 165);
  myGLCD.fillRoundRect (219, 0, 224, 160);
  myGLCD.drawLine(0, 57, 224, 57);
  myGLCD.drawLine(0, 58, 224, 58);
  myGLCD.print ("(TMP, C)", 45, 30);
  myGLCD.drawCircle(130, 36, 3);
  myGLCD.print ("HOUSE CLIMATE", 3, 5);
  myGLCD.print ("HALLWAY....", 3, 67);
  myGLCD.printNumI (tempH, 180, 70);
  myGLCD.print ("LAVATORY...", 3, 100);
  myGLCD.printNumI (tempL, 180, 100);
  myGLCD.print ("ROOM.......", 3, 130);
  myGLCD.printNumI (tempR, 180, 130);
void Infoext()
  myGLCD.fillRoundRect (219, 160, 224, 320);
  myGLCD.drawLine(0, 220, 224, 220);
  myGLCD.drawLine(0, 221, 224, 221);
  myGLCD.drawLine(224, 198, 480, 198);
  myGLCD.drawLine(224, 199, 480, 199);
  myGLCD.print ("OUTDOOR", 50, 172);
  myGLCD.print ("CLIMATE", 50, 195);
  myGLCD.print ("DEVICES STATUS", 242, 170);
  myGLCD.print ("TMP, C.....", 3, 230);
  myGLCD.drawCircle(73, 234, 3);
  myGLCD.printNumI (tempOut, 180, 230);
  myGLCD.print ("HUM, % ......", 3, 260);
  myGLCD.printNumI (humH, 180, 260);
  myGLCD.print ("PRES, mmHg.", 3, 290);
  myGLCD.printNumI (presH, 164, 290);
  L = digitalRead (Liht);
  if (L == HIGH)
    myGLCD.print ("Lihting.....", 230, 205);
    myGLCD.print ("OFF", 428, 205);
  else
    myGLCD.print ("Lihting......", 230, 205);
    myGLCD.setColor(VGA_GREEN);
    myGLCD.print (" ON", 430, 205);
  H = digitalRead (Heater);
  if (H == HIGH)
    myGLCD.print ("Heating.....", 230, 232);
    myGLCD.print ("OFF", 428, 232);
  else
    myGLCD.print ("Heating......", 230, 232);
    myGLCD.print (" ON", 430, 232);
  B = digitalRead (Boiler);
  if (B == HIGH)
    myGLCD.print ("Boiler......", 230, 262);
    myGLCD.print ("OFF", 428, 262);
  else
    myGLCD.print ("Boiler.......", 230, 262);
    myGLCD.print (" ON", 430, 262);
  F = digitalRead (Fridge);
  if (F == HIGH)
    myGLCD.print ("Fridge......", 230, 290);
    myGLCD.print ("OFF", 428, 290);
  else
    myGLCD.print ("Fridge.......", 230, 290);
    myGLCD.print (" ON", 430, 290);
void MainMenu ()
  myGLCD.clrScr();
Main:
  myGLCD.fillRect(0, 40, 480, 45);
  myGLCD.print("MAIN MENU", CENTER, 5);
  myGLCD.print("X", 5, 5);
  myGLCD.print("1. CONTROL MENU", 5, 75);
  myGLCD.print("2. SETUP MENU", 5, 155);
  myGLCD.setColor(VGA_BLUE);
  myGLCD.fillRoundRect (330, 65, 474, 112);
  myGLCD.fillRoundRect (330, 145, 474, 192);
  myGLCD.drawRoundRect (329, 64, 475, 113);
  myGLCD.drawRoundRect (329, 144, 475, 193);
  myGLCD.print("ENTER", 343, 65);
  myGLCD.print("ENTER", 343, 145);
  waitForTouch();
  myTouch.read();
  x = myTouch.getX();
  y = myTouch.getY();
  if ((x >= 330 && x <= 470) && (y >= 57 && y <= 105))
    ControlMenu ();
  if ((x >= 330 && x <= 470) && (y >= 124 && y <= 180 ))
    SetupMenu ();
  if ((x >= 0 && x <= 60) && (y >= 0 && y <= 60))
    myGLCD.clrScr();
    return;
void ControlMenu ()
  myGLCD.clrScr();
  myGLCD.print("CONTROL MENU", CENTER, 5);
  myGLCD.print("1.LIHTING CONTROL", 5, 65);
  myGLCD.print("2.HEATING CONTROL", 5, 135);
  myGLCD.print("3.BOILER CONTROL", 5, 205);
  myGLCD.print("4.FRIDGE CONTROL", 5, 275);
Control:
  if (L == HIGH)
    myGLCD.setColor (VGA_GREEN);
    myGLCD.fillRoundRect (310, 55, 475, 105);
    myGLCD.drawRoundRect (309, 54, 476, 106);
    myGLCD.setBackColor(VGA_GREEN);
    myGLCD.print ("Switch ON", 321, 65);
  else
    myGLCD.print ("Switch OFF", 312, 65);
  if (H == HIGH)
    myGLCD.fillRoundRect (310, 125, 475, 175);
    myGLCD.drawRoundRect (309, 124, 476, 176);
    myGLCD.print ("Switch ON", 321, 135);
  else
    myGLCD.print ("Switch OFF", 312, 135);
  if (B == HIGH)
    myGLCD.fillRoundRect (310, 195, 475, 245);
    myGLCD.drawRoundRect (309, 194, 476, 246);
    myGLCD.print ("Switch ON", 321, 205);
  else
    myGLCD.print ("Switch OFF", 312, 205);
  if (F == HIGH)
    myGLCD.fillRoundRect (310, 265, 475, 315);
    myGLCD.drawRoundRect (309, 264, 476, 316);
    myGLCD.print ("Switch ON", 321, 275);
  else
    myGLCD.setColor (VGA_WHITE);
    myGLCD.print ("Switch OFF", 312, 275);
  waitForTouch();
  myTouch.read();
  x = myTouch.getX();
  y = myTouch.getY();
  if ((x >= 316 && x <= 470) && (y >= 55 && y <= 97 ))
    Lihting ();
  if ((x >= 330 && x <= 470) && (y >= 125  && y <= 153 ))
    Heating ();
  if ((x >= 330 && x <= 470) && (y >= 196   && y <= 246))
    BoilerF ();
  if ((x >= 330 && x <= 470) && (y >= 271 && y <= 311))
    FridgeF ();
    myGLCD.clrScr();
    return;
  goto Control;
void SetupMenu ()
  myGLCD.clrScr();
  myGLCD.print("SETUP MENU", CENTER, 5);
  myGLCD.print("1.TIME SETUP", 5, 60);
  myGLCD.print("2.DATA SETUP", 5, 140);
  myGLCD.print("3.RESET", 5, 220);
  myGLCD.drawRoundRect (309, 50, 476, 100);
  myGLCD.drawRoundRect (309, 130, 476, 180);
  myGLCD.drawRoundRect (309, 209, 476, 259);
  myGLCD.fillRoundRect (310, 51, 475, 99);
  myGLCD.fillRoundRect (310, 131, 475, 179);
  myGLCD.fillRoundRect (310, 210, 475, 258);
  myGLCD.print("ENTER", 335, 51);
  myGLCD.print("ENTER", 335, 131);
  myGLCD.print("ENTER", 335, 210);
  waitForTouch ();
  myTouch.read();
  x = myTouch.getX();
  y = myTouch.getY();
  if ((x >= 320 && x <= 470) && (y >= 51 && y <= 99))
    TimeMenu();
  if ((x >= 320 && x <= 470) && (y >= 131  && y <= 179))
    DateMenu();
  if ((x >= 320 && x <= 470) && (y >= 210 && y <= 258))
    ResetMenu ();
void waitForTouch()
  while (myTouch.dataAvailable() == false)
void Lihting()
  if (N0 == 0)
    N0 = 1;
  else
    N0 = 0;
void Heating()
  if (N1 == 0)
    N1 = 1;
  else
    N1 = 0;
void BoilerF()
  if (N2 == 0)
    N2 = 1;
  else
    N2 = 0;
void FridgeF()
  if (N3 == 0)
    N3 = 1;
  else
    N3 = 0;
void ResetMenu()
  myGLCD.clrScr();
  delay (3000);
  resetFunc();
void TimeMenu ()
  H = time.Hours;
  m = time.minutes;
  s = time.seconds;
  myGLCD.clrScr();
  myGLCD.print("SETUP TIME", CENTER, 5);
  myGLCD.fillRoundRect(100 , 55 , 200 , 270);         // Hour edit field
  myGLCD.fillRoundRect(280 , 55 , 380 , 270);        // Min edit field
  myGLCD.fillRoundRect(161, 280 , 319, 310);
  myGLCD.print("SAVE DATA", CENTER, 280);
  myGLCD.drawRoundRect(160, 279 , 320, 311);
  if (H <= 9)
    myGLCD.print("0", 137, 144);
    myGLCD.printNumI(H, 155, 144);
  if (H > 9)
    myGLCD.printNumI(H, 137, 144);
  if (m <= 9)
    myGLCD.print("0", 305, 144);
    myGLCD.printNumI(m, 328, 144);
  if (m > 9)
    myGLCD.printNumI(m, 313, 144);
  myGLCD.fillCircle (150, 100, 35);     // +hour
  myGLCD.fillCircle (330, 100, 35);    // +min
  myGLCD.fillCircle (150, 220, 35);    // -hour
  myGLCD.fillCircle (330, 220, 35);   // -min
  myGLCD.print(" + ", 140, 75);       // +hour
  myGLCD.print(" + ", 318, 75);      // +min
  myGLCD.print(" - ", 140, 195);    // -hour
  myGLCD.print(" - ", 318, 195);    // -min
  waitForTouch();
  TimeSet();
void DateMenu ()
  d = time.day;
  M = time.month;
  Y = time.year;
  myGLCD.clrScr();
  myGLCD.print("SETUP DATE", CENTER, 5);
  myGLCD.fillRoundRect(40 , 55 , 140 , 270);         // Date edit field
  myGLCD.fillRoundRect(190 , 55 , 290 , 270);        // Month edit field
  myGLCD.fillRoundRect(340 , 55 , 440 , 270);        // Year edit field
  if (d <= 9)
    myGLCD.print("0", 75, 144);
    myGLCD.printNumI(d, 90, 144);
  if (d > 9)
    myGLCD.printNumI(d, 75, 144);
  if (M <= 9)
    myGLCD.print("0", 225, 144);
    myGLCD.printNumI(M, 240, 144);
  if (M > 9)
    myGLCD.printNumI(M, 225, 144);
  myGLCD.printNumI(Y, 375, 144);
  myGLCD.fillCircle (90, 100, 35);    // +date
  myGLCD.fillCircle (240, 100, 35);   // +month
  myGLCD.fillCircle (390, 100, 35);   // +Year
  myGLCD.fillCircle (90, 220, 35);     // -date
  myGLCD.fillCircle (240, 220, 35);    // -month
  myGLCD.fillCircle (390, 220, 35);    // -Year
  myGLCD.print(" + ", 83, 83);    // +date
  myGLCD.print(" + ", 233, 83);   // +month
  myGLCD.print(" + ", 383, 83);     // +Year
  myGLCD.print(" - ", 83, 203);     // -date
  myGLCD.print(" - ", 232, 203);  // -month
  myGLCD.print(" - ", 383, 203); // -Year
  waitForTouch();
  DateSet();
void DateSet()
Labeldate:
  myTouch.read();
  x = myTouch.getX();
  y = myTouch.getY();
  if (( x > 80 && x < 100  ) && (y > 80 && y < 110 )) // +date button pressed
    d = d + 1;
    if (d >= 31)
      d = 31;
    if (d <= 9)
    if (d >= 10)
    delay(200);
  if (( x > 80 && x < 100 ) && (y > 210 && y < 230 ))  // -date button pressed
    d = d - 1;
    if (d <= 1)
      d = 1;
    if (d <= 9)
    if (d > 9)
    delay(200);
  if (( x > 233 && x < 253 ) && (y > 80 && y < 110 ))   // +month button pressed
    M = M + 1;
    if (M >= 12)
      M = 12 ;
    if (M <= 9)
    if (M > 9)
    delay(200);
  if (( x > 230 && x < 250 ) && (y > 210 && y < 230 ))   // -month button pressed
    M = M - 1;
    if (M <= 1)
      M = 1;
    if (M <= 9)
    if (M >= 10)
    delay(200);
  if (( x > 390 && x < 410 ) && (y > 90 && y < 110 ))   // +Year button pressed
    Y = Y + 1;
    if (Y >= 100)
      Y = 21 ;
  delay(200);
  if (( x > 390 && x < 410 ) && (y > 210 && y < 230))   // -Year button pressed
    Y = Y - 1;
    if (Y <= 20)
      Y = 21;
  delay(300);
  if (( x > 220 && x < 280 ) && (y > 270 && y < 310 ))   // save button pressed
    byte day = d;                                                //число
    byte month =  M;                                            //месяц
    unsigned int year = Y;                                     //год
    unsigned int y = year - a;
    unsigned int y4 = f_div(y, 4);
    byte y100 = f_div(y, 100);
    byte y400 = f_div(y, 400);
    byte x = f_div(31 * m, 12);
    byte D = ((day + y + y4 - y100 + y400 + x) % 7);
    time.settime (-1, -1, -1, d, M, Y, D);
    resetFunc();
    goto Labeldate;
void TimeSet()
Labeltime:
  myTouch.read();
  x = myTouch.getX();
  y = myTouch.getY();
  if (( x > 126 && x < 175 ) && (y > 79 && y < 110 ))  // +hour button pressed
    H = H + 1;
    if (H >= 23)
      H = 23;
    if (H <= 9)
      myGLCD.print("0", 138, 144);
      myGLCD.printNumI(H, 163, 144);
    if (H > 9)
      myGLCD.printNumI(H, 138, 144);
    delay (200);
  if (( x > 140 && x < 170 ) && (y > 200 && y < 230 ))  // -hour button pressed
    H = H - 1;
    if (H <= 0)
      H = 0;
    if (H <= 9)
    if (H > 9)
    delay (200);
  if (( x > 320 && x < 340 ) && (y > 80 && y < 100 ))   // +min button pressed
    m = m + 1;
    if (m >= 59)
      m = 59 ;
    if (m <= 9)
      myGLCD.print("0", 330, 144);
      myGLCD.printNumI(m, 338, 144);
    if (m > 9)
    delay (200);
  if (( x > 330 && x < 360 ) && (y > 210 && y < 240 ))   // -min button pressed
    m = m - 1;
    if (m <= 0)
      m = 0;
    if (m <= 9)
      myGLCD.print("0", 313, 144);
    if (m > 9)
    delay (200);
  if (( x > 200 && x < 400 ) && (y > 270 && y < 315 ))   // Save button pressed
    time.settime (0, m, H);
    resetFunc();
  goto Labeltime;
unsigned int f_div(unsigned int X, unsigned int Y)
  unsigned int result;
  result = (X - (X % Y)) / Y;
  return result;
CAYENNE_OUT(0)
  Cayenne.virtualWrite(0, tempH);
CAYENNE_OUT(1)
  Cayenne.virtualWrite(1, humH);
CAYENNE_OUT(2)
  Cayenne.virtualWrite(2, presH);
CAYENNE_IN(4)
  CAYENNE_LOG("Channel %u, value %s", request.channel, getValue.asInt());
  L = getValue.asInt();
  if (L == 1)
  else
CAYENNE_IN(5)
  H = getValue.asInt();
  if (H == 1)
  else
CAYENNE_IN(6)
  B = getValue.asInt();
  if (B == 1)
  else
CAYENNE_IN(7)
  F = getValue.asInt();
  if (F == 1)
  else
that is pretty big code and cant go through it all now. can you just run the cayenne code and see if the issue occurs.
What does it mean to run the cayenne code? He works himself.
Most of the code is functions. Loop, in addition to kaen, contains calls to these functions. In addition, the Watchdog does not work, because its operation time is limited to 10 seconds, and the execution time of the Cayenne function is approximately 24 seconds.
Just a basic code and share the serial monitor output.
#define CAYENNE_DEBUG       // Uncomment to show debug messages
// Uncomment your modem type:
#define TINY_GSM_MODEM_SIM800
// #define TINY_GSM_MODEM_SIM808
// #define TINY_GSM_MODEM_SIM900
// #define TINY_GSM_MODEM_UBLOX
// #define TINY_GSM_MODEM_BG96
// #define TINY_GSM_MODEM_A6
// #define TINY_GSM_MODEM_A7
// #define TINY_GSM_MODEM_M590
// #define TINY_GSM_MODEM_ESP8266
// #define TINY_GSM_MODEM_XBEE
// This sketch uses a software serial connection.
#include <SoftwareSerial.h>
SoftwareSerial gsmSerial(2, 3); // RX, TX
// If you are using a device that supports a hardware serial (Mega, Leonardo, etc.) and prefer to use
// that you can comment out the above lines and uncomment the one below.
//#define gsmSerial Serial1
// GSM connection info.
char apn[] = ""; // Access point name. Leave empty if it is not needed.
char gprsLogin[] = ""; // GPRS username. Leave empty if it is not needed.
char gprsPassword[] = ""; // GPRS password. Leave empty if it is not needed.
char pin[] = ""; // SIM pin number. Leave empty if it is not needed.
	// Auto-detect the GSM serial baud rate. You can manually set it instead if you want to save a bit of space.
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
This code works without problems. The time between sending data to the server is about 24 seconds.
can you share the serial monitor output?
Yes, please.
in the above logs where do you see it takes 24 sec??
Yes, after I figured out the libraries Cayenne became 11 seconds. But for a watchdog job, that’s a lot. And the rest of the code doesn’t work fine either.
i dont know where it becomes 11 sec. the max it can go is 5 sec for downlink. you have also not included #include<avr/wdt.h> to use the watchdog timer.
I’m use GyverWDT library because wdt library not correctly worked with maga2560.
I use the A6 I-TNNKER A6 modem, which does not have built-in buffers for receiving and transmitting data. Do I need to use software buffers like #define TINY_GSM_RX_BUFFER 512?
i dont think the issue is the GSM or the cayenne code. It is the way you handle the timers.
