hi
iam using Cayenne free account and using esp32 device i can not create event and trigger
You need to add an if condition also.
I can’t select devices
By drag it
Do you have any devices added to your dashboard?
you need to drag the device from the left sidebar and drop it on the if field.
you need to drag the entire device (esp32) and not the widget in the device.
Trigger work correctly
But event
I cant select device
you need to have an actuator in your device so that you can set an event to it.
