In June I will animate a 2 day workshop on IoT at the African Internet Summit in Kampala, Uganda. We will use the WeMos D1 mini ESP8266 CPU card and a whole series of its sensors. I wanted to use The Cayenne MQTT Python client but found out that this relies on the Eclipse Paho MQTT library, not available on Micropython. I therefore ported this client class to make it work on the umqtt/simple.py MQTT client available in Micropython. The API is the same and the example programs work without modification.
I tested the library with a simple prototyping board featuring a photo resistor and an LED shining on it. The photo resistor is connected to the ESP8266 10 bit ADC while the LED is connected to D0 (GPIO 16).
I have BMP180,SHT30, a button, DS18B20, buzzer … shields which will all work with this Micropython Cayenne MQTT client
