Hello, I am facing issues connecting to cayenne to get accurate results from my DHT11 sensor. But I don’t think this issue is because of the board, sensor or wires because they are able to work when connected through Arduino and monitored using the serial monitor.
When connected with cayenne results are as such. I’ve tried several different codes but all seemed to yield the same results. Does anyone know the issue behind this problem?
Coding 1:
#define CAYENNE_DEBUG
#include <DHT.h>
char ssid = “xxxx”;
char wifiPassword = “xxxx”;
char username = “xxxx”;
char password = “xxxx”;
char clientID = “xxxx”;
DHT dht(2, DHT11);
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
float temp = dht.readTemperature(true); // Fahrenheit
float hum = dht.readHumidity();
Cayenne.virtualWrite(1, temp, TYPE_TEMPERATURE, UNIT_CELSIUS);
Cayenne.virtualWrite(2, hum, TYPE_RELATIVE_HUMIDITY, UNIT_PERCENT);
CAYENNE_IN(0)
digitalWrite(2, !getValue.asInt());
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Alternate coding 2:
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(2,DHT11);
char ssid = “xxxx”;
pinMode(2,OUTPUT);
digitalWrite(2,HIGH);
float temp = dht.readTemperature(HIGH);//celsius
Results in Cayenne:
