New to this but can get my ESP8266 NodeMCU to connect to Cayenne and show the automatic test values, but trying to connect any actual sensors is an exercise in futility and many errors.
So, instead of both sensors (I can get them working along to the serial monitor, but not to IoT Cayenne), I’ll try starting with the DHT22, but still many issues.
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
//#define CAYENNE_DEBUG
#include <DHT.h>
#define DHTPIN 6 // Digital pin connected to the DHT22 sensor
#define DHTTYPE DHT22 // DHT22 (AM2302)
DHT dht(DHTPIN, DHTTYPE);
char ssid[] = "vodafoneAAZGBF";
char wifiPassword[] = "af9YsnfFzcYcRkaz";
char username[] = ":-)";
char password[] = "blablabla";
char clientID[] = ":-)";
Serial.begin(115200);
dht.begin;}
int chk = DHT.read(DHTPIN);
float temp = DHT.temperature;
float hum = DHT.humidity;
Cayenne.virtualWrite(1, temp, TYPE_TEMPERATURE, UNIT_Celsius)
Cayenne.virtualWrite(2, hum, TYPE_HUMIDITY, UNIT_Percent)}
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Here are my error codes, and even with ChatGPT I’m not understanding what is wrong. Should be simple right? No.
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\Aaron\AppData\Local\Temp\arduino_modified_sketch_766695\ESP8266.ino: In function 'void setup()':
ESP8266:36:7: error: invalid use of non-static member function 'void DHT::begin(uint8_t)'
36 | dht.begin;}
In file included from C:\Users\Aaron\AppData\Local\Temp\arduino_modified_sketch_766695\ESP8266.ino:18:
C:\Users\Aaron\Documents\Arduino\libraries\DHT_sensor_library/DHT.h:66:8: note: declared here
66 | void begin(uint8_t usec = 55);
C:\Users\Aaron\AppData\Local\Temp\arduino_modified_sketch_766695\ESP8266.ino: In function 'void loop()':
ESP8266:40:15: error: expected primary-expression before '.' token
40 | int chk = DHT.read(DHTPIN);
ESP8266:41:18: error: expected primary-expression before '.' token
41 | float temp = DHT.temperature;
ESP8266:42:17: error: expected primary-expression before '.' token
42 | float hum = DHT.humidity;
ESP8266:43:50: error: 'UNIT_Celsius' was not declared in this scope
43 | Cayenne.virtualWrite(1, temp, TYPE_TEMPERATURE, UNIT_Celsius)
exit status 1
