Hi guys,
I had just started with cayenne recently and started coding a watering system/hrv micro controller for my house, and now i have to convert it to mqtt - What i am having trouble with is, when i put cayenne.begin into my code, my ds18b20 chain stops reading - without the cayenne.begin everything reads and responds fine. If i run one sensor it seems to work ok as well, but as soon as theres a true one wire bus with more than one sensor it loses the plot.
Will I have to do individual pins for my sensors, or is there something else to fix it? Im not experienced in coding, obviously enough. Most of the bottom of the code is commented out for now as problem solving.
Cheers
Brendon
#include <OneWire.h>
#define CAYENNE_DEBUG
char username[] = "x";
char password[] = "x";
char clientID[] = "x";
unsigned long lastMillis = 0;
const int tmpPin = 3; //dallas one wire sensor on pin3
OneWire oneWire(tmpPin);
const float sensorPin = A0; // select the input pin for the potentiometer
const int relayPin = 2; // select the pin for the relay
float moisture = 0; // variable to store the value coming from the sensor
const int fanPin = 5; // fan output pin
// declare the ledPin as an OUTPUT:
pinMode(relayPin, OUTPUT);
pinMode(fanPin, OUTPUT);
pinMode(sensorPin, INPUT);
// read the value from the sensor:
moisture = analogRead(sensorPin);
moisture = (moisture / 700) * 100;
Serial.println("");
Serial.println("Temperatures in house");
Serial.println("=====================");
Serial.print("Temperature OUTSIDE is: ");
Serial.println(sensors.getTempCByIndex(0));
delay(1000);
Serial.print("Temperature CEILING is: ");
Serial.println(sensors.getTempCByIndex(1));
delay(1000);
Serial.print("Temperature ROOM is: ");
Serial.println(sensors.getTempCByIndex(2));
delay(1000);
Cayenne.virtualWrite(1, moisture, UNIT_PERCENT);
////////////////////////////////// HRV SYSTEM ///////////////////////////////////////
if (sensors.getTempCByIndex(0) > sensors.getTempCByIndex(1))
Serial.println("high temp");
digitalWrite(5, HIGH);
else
Serial.println("low temp");
digitalWrite(5, LOW);
Serial.println("end of loop, waiting 3 seconds");
delay(3000);
///////////////////////////////////// WATERING SYSTEM /////////////////////////////////
Serial.println("");
Serial.println("");
Serial.println("Garden Moisture Levels");
Serial.print("Moisture is: ");
Serial.print(moisture);
Serial.println("%");
// turn the WATERING RELAY ON on
if (moisture < 30)
Serial.println("Moisture is less than 30%, starting watering system");
digitalWrite(relayPin, HIGH);
else
Serial.println("Moisture is above 30%, watering not required");
digitalWrite(relayPin, LOW);
/* Cayenne.loop();
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(0, sensors.getTempCByIndex(0));
Cayenne.virtualWrite(1, sensors.getTempCByIndex(1));
Cayenne.virtualWrite(2, sensors.getTempCByIndex(2));
Cayenne.virtualWrite(3, moisture);
CAYENNE_IN_DEFAULT()
