Hi community, I need some support on my project MQTT migration.
The project is very simple, 2 relay and 1 ds18b20. Before everythings worked fine. Now I’m not able to manage the ds18b20. I was able to reinstall the 2 relays and they work, but once I try to implement the sketch to manage the sensor it stops to work and I’m not able to manage the project via web or mobile. I attach the sketch just to verify but it’s very simple. The sensor is attached to arduino pin 7.
Arduino UNO and esp8266
I installed of course the MQTT libraries and tryed dozen of sketch combination but I’m not able to go forward
Thanks in advance
#include <OneWire.h>
char ssid[] = "xxxxxxx";
char wifiPassword[] = "xxxxx";
char username[] = "xxxxx";
char password[] = "xxxxx";
char clientID[] = "xxxxx";
#define ACTUATOR_PIN8 8// Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define ACTUATOR_PIN9 9 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL 3
#define sensorpin 7 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
OneWire oneWire(sensorpin);
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
pinMode(ACTUATOR_PIN8, OUTPUT);
pinMode(ACTUATOR_PIN9, OUTPUT);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
digitalWrite(ACTUATOR_PIN8, HIGH);
digitalWrite(ACTUATOR_PIN9, HIGH);
CAYENNE_IN(1)
if (getValue.asInt() == 0) {
else {
digitalWrite(ACTUATOR_PIN8, LOW);
CAYENNE_IN(2)
else {
digitalWrite(ACTUATOR_PIN9, LOW);
CAYENNE_IN(3)
//sensors.requestTemperatures();
//Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
//Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL, sensors.getTempFByIndex(0));
