I have some problems converting this code. Can someone assist with converting this code to Cayenne?
#include <Arduino.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#include "tinySPI.h"
#include "BME280Spi.h"
#include "LoRaWAN.h"
#include "secconfig.h" // remember to rename secconfig_example.h to secconfig.h and to modify this file
// RFM95W
#define DIO0 10
#define NSS 9
RFM95 rfm(DIO0, NSS);
// define LoRaWAN layer
LoRaWAN lora = LoRaWAN(rfm);
// frame counter for lora
unsigned int Frame_Counter_Tx = 0x0000;
// BME280 SPI Chipselect pin
#define BME_CS 7
// Default : forced mode, standby time = 1000 ms
//Oversampling = pressure ×1, temperature ×1, humidity ×1, filter off
BME280Spi::Settings settings(BME_CS);
BME280Spi bme(settings);
// the things network stuff
// get them from the device overview page! uncomment and put this information here, remove the #include secconfig.h
// due to security reasons this information from the author is put in secconfig.h
// TTN, msb left
// unsigned char NwkSkey[16] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
// unsigned char AppSkey[16] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
// unsigned char DevAddr[4] = { 0x00, 0x00, 0x00, 0x00 };
// sleep cycles that will be counted, start with more than sleep_total to start after 8 seconds with first broadcast.
volatile int sleep_count = 38;
// set sleep time between broadcasts. The processor awakes after 8 seconds deep-sleep_mode,
// increase and checks the counter and sleep again until sleep_total is reached.
// 5min * 60s = 300/8 = 37,5 = 38.
// 17 seconds longer than 5 minutes with 37, so 35 is more apropriate
const int sleep_total = 35; // was 35
// all functions declared
ISR(WDT_vect);
void readData(float &temp, float &hum, float &press);
uint16_t vccVoltage();
void setUnusedPins();
void goToSleep();
void watchdogSetup();
// define unused pins
setUnusedPins();
//Initialize RFM module
rfm.init();
lora.setKeys(NwkSkey, AppSkey, DevAddr);
// for BME sensor
while(!bme.begin())
// Serial.println("Could not find BME280 sensor!");
delay(200);
// goToSleep for all devices...
// The watchdog timer will reset.
goToSleep();
// use this for non-sleep testing:
//delay(8000);
//sleep_count++;
// do action if sleep_total is reached
if (sleep_count >= sleep_total)
uint16_t tempInt;
uint16_t humInt;
// define bytebuffer
uint8_t Data_Length = 0x06;
uint8_t Data[Data_Length];
float temp, hum, press;
// read data from sensor
readData(temp, hum, press);
// from float to uint16_t
tempInt = temp * 100;
humInt = hum * 100;
// read vcc voltage (mv)
uint16_t vcc = vccVoltage();
Data[0] = (vcc >> 8) & 0xff;
Data[1] = (vcc & 0xff);
// move into bytebuffer
Data[2] = (tempInt >> 8) & 0xff;
Data[3] = tempInt & 0xff;
Data[4] = (humInt >> 8) & 0xff;
Data[5] = humInt & 0xff;
lora.Send_Data(Data, Data_Length, Frame_Counter_Tx);
Frame_Counter_Tx++;
// reset sleep count
sleep_count = 0;
set unused pins so no undefined situation takes place
// 0, 1, 2, 3, 8
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
read temperature from BME sensor
// set units sensor
BME280::TempUnit tempUnit(BME280::TempUnit_Celsius);
BME280::PresUnit presUnit(BME280::PresUnit_Pa);
// read sensor (SPI interface)
bme.read(press, temp, hum, tempUnit, presUnit);
read voltage of the rail (Vcc)
output mV (2 bytes)
// Read 1.1V reference against AVcc
// set the reference to Vcc and the measurement to the internal 1.1V reference
// default ADMUX REFS1 and REFS0 = 0
// #define _BV(bit) (1 << (bit))
// 1.1V (I Ref)(2) 100001
ADMUX = _BV(MUX5) | _BV(MUX0);
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Start conversion
while (bit_is_set(ADCSRA,ADSC)); // measuring
uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
uint8_t high = ADCH; // unlocks both
uint16_t result = (high<<8) | low;
// result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
// number of steps = 1023??
result = (1125300L / result) ; // Calculate Vcc (in mV);
return result;
// Table for clearing/setting bits
//WDP3 - WDP2 - WPD1 - WDP0 - time
// 0 0 0 0 16 ms
// 0 0 0 1 32 ms
// 0 0 1 0 64 ms
// 0 0 1 1 0.125 s
// 0 1 0 0 0.25 s
// 0 1 0 1 0.5 s
// 0 1 1 0 1.0 s
// 0 1 1 1 2.0 s
// 1 0 0 0 4.0 s
// 1 0 0 1 8.0 s
// Reset the watchdog reset flag
bitClear(MCUSR, WDRF);
// Start timed sequence
bitSet(WDTCSR, WDCE); //Watchdog Change Enable to clear WD
bitSet(WDTCSR, WDE); //Enable WD
// Set new watchdog timeout value to 8 second
bitSet(WDTCSR, WDP3);
bitClear(WDTCSR, WDP2);
bitClear(WDTCSR, WDP1);
bitSet(WDTCSR, WDP0);
// Enable interrupts instead of reset
bitSet(WDTCSR, WDIE);
void goToSleep()
//Disable ADC, saves ~230uA
ADCSRA &= ~(1<<ADEN);
watchdogSetup(); //enable watchDog
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
// sleep_mode does set and reset the SE bit. sleep_enable and sleep_disable are not usefull
sleep_mode();
//disable watchdog after sleep
wdt_disable();
// enable ADC
ADCSRA |= (1<<ADEN);
ISR(WDT_vect)
sleep_count++; // keep track of how many sleep cycles have been completed.
Hardware setup
Attiny84 using the Arduino pin numbers! PB0 = 0 etc.
Atmel ATtiny84A PU
RFM95W
BME280
Power: 3V3 - 470uF elco over power connectors, 100nF over power connector for interference suppression
Connections:
RFM95W ATtiny84
DIO0 -- PB0
MISO -- MOSI
MOSI -- MISO
SCK -- SCK
NSS -- PB1 (this is Chipselect)
Bosch BME280 sensor used with tinySPI....
BME280 ATtiny84
SCL -- SCK
SDA -- MISO
SDO -- MOSI
CSB -- PA7 (this is Chipselect)(Arduino pin 7)
