Creation of a pulsation counter
I’m sorry but I had already tried, and serialprint = 0.00
can you share your code?
How can i share my code ?
copy and paste i guess.
The code was already pasted in another answer
#include <EEPROM.h>
#include <OneWire.h>
char username = “3f12e5f0-b73d-11e6-b51c-abe30c418779”;
char password = “388d4c05edd69614cb7f6438685a3cdfcb3643d2”;
char clientID = “7d5c11a0-4854-11ea-b73d-1be39589c6b2”;
#define CAYENNE_DEBUG
#define SENSOR_PIN 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL6 6
#define LEDR_PIN 6 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
OneWire oneWire(SENSOR_PIN);
// constants won’t change. They’re used here to set pin numbers:
const int BUTTON_PIN = 5; // the number of the pushbutton pin
// variables will change:
int BUTTON_PINState; // variable for reading the
int value;
int countTours;
float Kilos;
int addr = 0;
int addr1 = 1;
sensors.begin();
pinMode(BUTTON_PIN, INPUT);
pinMode(LEDR_PIN, OUTPUT);
//float Kilos =(countTours/3);
int BUTTON_PINState = digitalRead(5);
if ( BUTTON_PINState == 1)
countTours++;
ecrireEEprom();
lireEEprom();
Serial.print("countTours= " );
Serial.println(countTours);
Serial.print("Kilos = " );
Serial.println(Kilos);
CAYENNE_OUT(2)
Cayenne.celsiusWrite(2, sensors.getTempCByIndex(0));
CAYENNE_OUT(5)
Cayenne.virtualWrite(5, digitalRead(BUTTON_PIN), “digital_sensor”, “d”);
// read the state of the pushbutton value:
BUTTON_PINState = digitalRead(BUTTON_PIN);
CAYENNE_IN(VIRTUAL_CHANNEL6)
if (getValue.asInt() == 0)
digitalWrite(LEDR_PIN, HIGH);
else
digitalWrite(LEDR_PIN, LOW);
CAYENNE_OUT(7)
Cayenne.virtualWrite(7, Kilos); //virtual pin1
CAYENNE_OUT(8)
Cayenne.virtualWrite(8, countTours); //virtual pin1
CAYENNE_CONNECTED()
//if (isFirstConnect) {
Cayenne.syncAll();
void ecrireEEprom()
EEPROM.write(addr, countTours);
EEPROM.write(addr1, Kilos);
void lireEEprom()
countTours = EEPROM.read(addr);
Kilos = EEPROM.read(addr1);
void UpdateEEprom()
EEPROM.update (addr, countTours);
EEPROM.update (addr1, Kilos);
Miracle, now it works, yet I haven’t changed anything
Thanks for your help
