Hello
I try to create a counter showing the number of turns that a screw has turned, and another that increases by 1 when the screw has turned 30 turns
but I don’t know which widget to use, and I don’t know if my program is good
Thank you for your help
#include <OneWire.h>
char username = “3f12e5f0-b73d-11e6-b51c-abe30c418779”;
char password = “388d4c05edd69614cb7f6438685a3cdfcb3643d2”;
char clientID = “7d5c11a0-4854-11ea-b73d-1be39589c6b2”;
#define CAYENNE_DEBUG
#define SENSOR_PIN 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL2 2
//#define BUTTON_PIN 5 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL5 5
#define VIRTUAL_CHANNEL6 6
#define LEDR_PIN 6 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_PIN_KILOS V1
#define VIRTUAL_PIN_TOURS V2
OneWire oneWire(SENSOR_PIN);
// constants won’t change. They’re used here to set pin numbers:
const int BUTTON_PIN = 5; // the number of the pushbutton pin
// variables will change:
int BUTTON_PINState; // variable for reading the
int value;
int countTours;
int Kilos;
sensors.begin();
pinMode(BUTTON_PIN, INPUT);
pinMode(LEDR_PIN, OUTPUT);
int BUTTON_PINState = digitalRead(5);
int Kilos = (countTours/30);
if ( BUTTON_PINState == 1)
countTours++;
Serial.print("countTours= " );
Serial.println(countTours);
Serial.print("Kilos = " );
Serial.println(Kilos);
CAYENNE_OUT(1)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL2, sensors.getTempCByIndex(0));
CAYENNE_OUT(2)
Cayenne.virtualWrite(VIRTUAL_CHANNEL5, digitalRead(BUTTON_PIN), “digital_sensor”, “d”);
// read the state of the pushbutton value:
BUTTON_PINState = digitalRead(BUTTON_PIN);
CAYENNE_IN(VIRTUAL_CHANNEL6)
if (getValue.asInt() == 0)
digitalWrite(LEDR_PIN, HIGH);
else
digitalWrite(LEDR_PIN, LOW);
CAYENNE_OUT(KILOS)
Cayenne.virtualWrite(VIRTUAL_PIN_KILOS, Kilos); //virtual pin1
CAYENNE_OUT(TOURS)
Cayenne.virtualWrite(VIRTUAL_PIN_TOURS, countTours); //virtual pin1
