ESP8266 goes offline when processing a function
Hie all
I am using a wemos d1 mini and an node mcu board. I have tried this on both boards with the same issue. I am using both the android and web dashboards.
The problem i am having is that when i run a scheduled task or manually activate a button in the dashboard, the system will run for about 2 minutes before "going offline until said event/process has finished. Example: I have a button in my dashboard which activates a relay for 3 minutes and then shuts off the relay. When i press the button, the relay switches on as expected but about 1.5 to 2 minutes into the relay being on, the dashboard shows as offline and i get an email notification saying my device is offline. (I set an alert to tell me when the device goes offline.)
here is my code
//#define CAYENNE_DEBUG
char ssid[] = "CAYENNEFTW";
char wifiPassword[] = "IH8PPLE";
char username[] = "+++++++++++++++++++++++++++++++++++++";
char password[] = "+++++++++++++++++++++++++++++++++++++";
char clientID[] = "+++++++++++++++++++++++++++++++++++++++";
int soillevel = analogRead(A0);
pinMode(5,OUTPUT); //Set pin 5 as OUTPUT pin, to send signal to relay
CAYENNE_OUT(0)
  int x  = analogRead(A0);
  int w = (x-24)/10;
  Cayenne.virtualWrite(0, w);
CAYENNE_OUT(1)
      Cayenne.virtualWrite(2, digitalRead(5));
// This function will be called every time a Dashboard widget writes a value to Virtual Channel 4.
CAYENNE_IN(2)
  int val1 = getValue.asInt();
  digitalWrite(5, val1);
  delay(180000);
CAYENNE_IN_DEFAULT()
CAYENNE_OUT_DEFAULT()
  Cayenne.virtualWrite(3, millis());
My Dash
you cannot use delay in the loop. try to use millis to count the amount of time.
Hi thank you for your help.
I have tried using millis but the relay witches on and stays on. Please see my code below:
#include <SimpleTimer.h>
 SimpleTimer timer;
int  State = LOW; //initial state of relay pin
const long interval = 5000;
int waterlevel = digitalRead(5);
CAYENNE_OUT(0)
//Analog Sensor
  int w = (x-24)/10;
CAYENNE_OUT(1)
      //Read State of pin 5
// This function will be called every time a Dashboard widget writes a value to Virtual Channel 2.
CAYENNE_IN(2)
  if (currentMillis - previousMillis >= interval) {
    previousMillis = currentMillis+5000UL;
if (getValue.asInt() == 1)// if the button on dash has been turned on
State = HIGH; // Switch on Relay
 else
      State = LOW; //Turn off relay
      digitalWrite(5, State);
   previousMillis = millis();
Any advice is greatly appreciated. Thank you!
this function is only called when there is message received from cayenne hence the code inside the function will run only once and the counting of time wont happen. Use an variable and count the time in the main loop.
Thank you. Is there an example that i can follow? or pseudo code? Im new to the millis function and it seems to be a bit complicated. I appreciate you assistance you have been very helpful.
Something like this:
if (start){
   if(millis() - lastMillis > 10000) {
      digitalWrite(5, 0);
      start = false;
CAYENNE_IN(2)
 start = true;
digitalWrite(5, 1);
lastMillis = millis();
Hi thank you i have managed to get it working. Thank you very much for your help. The ESP8266 stays on now.
