Good morning everybody,
I need some help.
I realized a weather station made with an Arduino MKR1310 that send to a Lora TTN Gateway and I see my data on Cayenne.
All is working for several months.
Now, I want to turn on/off one or more outputs on my Arduino.
Can you help me with some examples? I’m using “CayenneLPP.h” format. How I can read the downlink payload and how I can set the button in the web application in Cayenne?
#include <TheThingsNetwork.h>
#include <CayenneLPP.h>
// Set your AppEUI and AppKey
const char *appEui = "xxxx";
const char *appKey = "xxxx";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_US915
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
CayenneLPP lpp(51);
loraSerial.begin(57600);
debugSerial.begin(9600);
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 10000)
ttn.onMessage(message);
debugSerial.println("-- STATUS");
ttn.showStatus();
debugSerial.println("-- JOIN");
ttn.join(appEui, appKey);
int x;
debugSerial.println("-- LOOP");
x++;
lpp.reset();
lpp.addTemperature(1, x);
lpp.addAnalogOutput(22, 2);
lpp.addDigitalOutput(7, 1);
// Send it off
ttn.sendBytes(lpp.getBuffer(), lpp.getSize());
delay(10000);
void message(const uint8_t *payload, size_t size, port_t port)
debugSerial.println("-- MESSAGE");
debugSerial.print("Received " + String(size) + " bytes on port " + String(port) + ":");
for (int i = 0; i < size; i++)
debugSerial.print(" " + String(payload[i]));
debugSerial.println();
if ( payload[2] == 100)
debugSerial.println("ON");
else
debugSerial.println("OFF");
Thank you,
the library "TheThingsNetwork.h"doesn’t wok with MKR WAN 1310. I’m using “MKRWAN.h”.
Can you help me?
can you share the library GitHub link and the code you are using?
#include <MKRWAN.h>
#include <DHT.h>
#include "ArduinoLowPower.h"
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define DEBUG
LoRaModem modem;
CayenneLPP lpp(51);
const char *appEui = "XXX";
const char *appKey = "XXXXX";
/*--- SETUP ---*/
if (!modem.begin(EU868)) {
Serial.println("Failed to start module");
while (1) {}
#ifdef DEBUG
Serial.print("Versione del modulo: ");
Serial.println(modem.version());
Serial.print("EUI: ");
Serial.println(modem.deviceEUI());
#endif
int connected = modem.joinOTAA(appEui, appKey);
if (!connected) {
Serial.println("Qualcosa è andato storto; sei all'interno? Vai vicino alla finestra e riprova");
while (1) {}
// Set poll interval to 60 secs.
modem.minPollInterval(60);
/*--- LOOP ---*/
lpp.reset();
lpp.addTemperature(1, temperatura_esterna);
lpp.addRelativeHumidity(2, umidita_esterna);
lpp.addBarometricPressure(3, pressione_esterna);
lpp.addTemperature(4, temperature);
lpp.addAnalogInput(5, VWind);
lpp.addAnalogInput(6, Wind);
lpp.addAnalogInput(7, Voltage);
modem.beginPacket();
modem.write(lpp.getBuffer(), lpp.getSize());
err = modem.endPacket(true);
if (err > 0) {
SendData = false;
} else {
LowPower.deepSleep(60000);
MKRWAN.h is the library for MKR1310 in the Arduine IDE
i do see there is a downlink example here MKRWAN/LoraSendAndReceive.ino at master · arduino-libraries/MKRWAN · GitHub
Thank you,
I 'll try it with Cayenne.
just to note the downlink is in the format of
01 0064 FF
Channel 01
Value 1.0
01 0000 FF
Channel 01
Value 0.0
