dorustd
November 17, 2019, 9:07am
Hi
I would like to see my DHT22 data in Cayenne.
I am using The Things Uno board. I have connected DHT22. I have
It is working correctly in TTN. Showing the dynamic sensor data. Temperature and Humidity.
Also I have tested arduino-device-lib/CayenneLPP.ino at master · TheThingsNetwork/arduino-device-lib · GitHub
It is working correctly in TTN and it shows static values in Cayenne Dasboard.
I don’t know how to adapt this sketch to combine previous sketch with CayenneLPP sketch.
debugSerial.println(“-- LOOP”);
//lpp.reset ();
lpp.addTemperature(1, 22.5);
lpp.addRelativeHumidity(2, 80.21);
lpp.addGPS(3, 52.37365, 4.88650, 2);
I need help…
you just need to send the DHT data in cayenne lpp format:
lpp.addTemperature(5, t);
dorustd
November 18, 2019, 8:24pm
3
Thank you. I am almost there!
I have changed the sketch:
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
CayenneLPP lpp(51); // create a buffer of 51 bytes to store the payload
lpp.addTemperature(1, t);
float h = dht.readHumidity();
lpp.addRelativeHumidity(2, h);
ttn.sendBytes(lpp.getBuffer(), lpp.getSize());
delay(10000);
Values are sent TTN and Cayenne.
Cayenne shows incorrect values:
and sometimes 0 values.
do what you know what is wrong?
Add debug lines in your code to check that you are getting correct reading from DHT first.
dorustd
November 19, 2019, 11:23am
5
How do I do that?
Can you give me debug lines example?
this is a debug line which prints out to the serial monitor.
dorustd
November 19, 2019, 6:44pm
7
Thank you…solved.
19:39:25.688 → Sending: mac tx uncnf 1 01670102026854
19:39:27.825 → Successful transmission
19:39:37.818 → – LOOP
19:39:37.853 → 25.30
19:39:37.853 → 43.10
I have added dht.begin(); in the void setup() section.
I was forgottten.
normal values , see below screenshot.
