hi just got my first sensor working, but my goal is to have 3 temp sensors and one luminosity sensor.
but when adding the second DS18B20 widget, the sketch has not included the first one. anyone have an idea for the code for two or 3 sensors?
Here is mine with the arduino uno with a 5100 sheild an one DS18b20 sensor:
#include <OneWire.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <EthernetServer.h>
#include <Dhcp.h>
#include <EthernetClient.h>
#include <Dns.h>
#include <util.h>
Cayenne DS18B20 Example
This sketch shows how to send temperature data to a DS18B20 Sensor in the Cayenne Dashboard.
Steps:
1. Install the OneWire library (http://www.pjrc.com/teensy/td_libs_OneWire.html) from the Arduino Library Manager.
2. Install the DallasTemperature library (http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library#Code.2FLibrary) from the Arduino Library Manager.
3. In the Cayenne Dashboard add a new DS18B20 widget.
4. Set the widget to Value Display.
5. Select Virtual Pins and a virtual pin number.
6. Set VIRTUAL_PIN to the pin number you selected.
7. Attach a DS18B20 to an digital pin on your Arduino.
Schematic:
[Ground] -- [DS18B20] -- [4.7k resistor] -- [5V]
|______________|
Digital Pin
8. Set the tmpPin variable to match the pin used to connect the DS18B20.
9. Set the token variable to match the Arduino token from the Dashboard.
10. Compile and upload this sketch.
11. Once the Arduino connects to the Dashboard it should automatically update the DS18B20 widget with data.
#include <CayenneEthernet.h>
#define VIRTUAL_PIN V1
const int tmpPin = 7;
OneWire oneWire(tmpPin);
char token[] = "";
Cayenne.begin(token);
sensors.begin();
CAYENNE_OUT(VIRTUAL_PIN)
Cayenne.celsiusWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
Just a matter of (like you suggested kuncono) repeating alot of variables. But the trick is to remember to make them all unique.
There is proberly a smarter way of looping or array it but again im not a coding guy.
Here’s my working example of 3 sensors on the arduino uno:
#include <SPI.h>
#include <Dhcp.h>
#include <Dns.h>
#include <util.h>
Steps:
Schematic:
|______________|
Digital Pin
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
#define VIRTUAL_PIN3 V3
const int tmpPin1 = 7;
const int tmpPin2 = 6;
const int tmpPin3 = 5;
OneWire oneWire1(tmpPin1);
OneWire oneWire2(tmpPin2);
OneWire oneWire3(tmpPin3);
DallasTemperature sensors1(&oneWire1);
DallasTemperature sensors2(&oneWire2);
DallasTemperature sensors3(&oneWire3);
char token[] = "xxxx";
sensors1.begin();
sensors2.begin();
sensors3.begin();
CAYENNE_OUT(VIRTUAL_PIN1)
sensors1.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN1, sensors1.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN2)
sensors2.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN2, sensors2.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN3)
sensors3.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN3, sensors3.getTempCByIndex(0));
Hi tvj, thank you!
You state you are not a “coding guy”, and yet you have a working example, on the contrary, all those smart technical people who boast lots of higher knowledge, still did not practically solve the issue.
What are you looking to do? This thread is explaining how to add more DS18B20 sensors to an Arduino device using the Arduino IDE. If you scroll up to post 5 you’ll see the code to do it.
#define SENSOR1_PIN 2// Temperature sensor on LED ligths.
#define SENSOR2_PIN 3// Temperature sensor on Aquarium.
#define SENSOR3_PIN 4// Temperature sensor on Control Unit.
#define VIRTUAL_CHANNEL 1
#define VIRTUAL_CHANNEL 2
#define VIRTUAL_CHANNEL 3
OneWire oneWire1(SENSOR1_PIN);
OneWire oneWire2(SENSOR2_PIN);
OneWire oneWire3(SENSOR3_PIN);
sensors.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL 1)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL 1, sensors1.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL 2)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL 1, sensors2.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL 3)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL 3, sensors3.getTempCByIndex(0));
You have some extra ; in there, and it’s been a long time since I used the DallasTemperature library, but looks ok other than that. Are you getting errors, or noticing that something doesn’t work?
I think latest DS18B20 library INCLUDES the 1-wire library and you should not include it separately in your code. If you get errors about 1-wire stuff being redefined, that’s the problem.
