How can I connect two DS18B20 Temperature sensor with cayenne?
Please help me with this complete code and circuit connections.
Cayenne DS18B20 Example
This sketch shows how to send DS18B20 Sensor data to the Cayenne Dashboard.
Steps:
- Install the OneWire library (OneWire Arduino Library, connecting 1-wire devices (DS18S20, etc) to Teensy) from the Arduino Library Manager.
- Install the DallasTemperature library (Miles Burton - Innovative engineering for pretty much anything) from the Arduino Library Manager.
- Attach a DS18B20 to a digital pin on your Arduino.
Schematic:
[Ground] – [DS18B20] – [4.7k resistor] – [5V]
|______________|
Digital Pin - Set the SENSOR_PIN value below to the pin number you used when connecting the sensor.
- Set the VIRTUAL_CHANNEL value below to a free virtual channel (or the virtual channel of a DS18B20 Sensor widget you have added) in the Dashboard.
- Compile and upload this sketch.
- Once the Arduino connects to the Dashboard it should automatically create a temporary display widget (or update the DS18B20 Sensor widget you have added) with data.
To make a temporary widget permanent click the plus sign on the widget.
#include <OneWire.h>
char username = “62c74310-b143-11e6-9ce1-1904e26cb7a0”;
char password = “f095c9b1072071dec0dfad2011e254e8b36f283c”;
char clientID = “3e70aa50-2658-11ea-8221-599f77add412”;
#define SENSOR_PIN 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL undefined
OneWire oneWire(SENSOR_PIN);
sensors.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
//Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL, sensors.getTempFByIndex(0));
