Good evening friends, I need to include two relays in my project to connect two lamps. I’m using NodeMCU Esp8266. I have saved this code via IDE, but when I add new Widget (custom widgets / button) and added but I can not trigger the relay.
Code I used following the tutorial:
//#define CAYENNE_DEBUG
char ssid = “((MP))”;
char wifiPassword = “xxxxxxx”;
char username = “xxxxxxxxxxxxxxxxxxxxxx”;
char password = “xxxxxxxxxxxxxxxxxxxxxx”;
char clientID = “xxxxxxxxxxxxxxxxxxxxxxxx”;
unsigned long lastMillis = 0;
CAYENNE_OUT_DEFAULT()
Cayenne.celsiusWrite(1, 22.0);
Cayenne.luxWrite(2, 700);
Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
