I guess I need a bit of help. If anyone can help me kick the can down the road that would be awesome.
I got my ESP32 to connect to the Wi-Fi network but Im not able to connect to MyDevices or more to the point Connecting to mqtt.mydevices.com:1883
I used the code pasted below, but Im missing something.
What is the SSIDc and PasswordC
Also should I be using the ESP8266 selection from ADD NEW or do I use BRING MY OWN DEVICE. I choose Bring My Own and populated the code with those credentials.
12:56:42.352 -> ets Jun 8 2016 00:22:57
12:56:42.352 ->
12:56:42.352 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
12:56:42.760 -> ets Jun 8 2016 00:22:57
12:56:42.760 ->
12:56:42.760 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
12:56:42.760 -> configsip: 0, SPIWP:0xee
12:56:42.760 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
12:56:42.760 -> mode:DIO, clock div:1
12:56:42.760 -> load:0x3fff0018,len:4
12:56:42.760 -> load:0x3fff001c,len:1100
12:56:42.760 -> load:0x40078000,len:10088
12:56:42.760 -> load:0x40080400,len:6380
12:56:42.760 -> entry 0x400806a4
12:56:43.514 -> Connecting to WiFi…
12:56:44.030 -> Connecting to WiFi…
12:56:44.030 -> Connected to the WiFi network
12:56:44.508 -> [1669] Connecting to Linksys
12:56:44.541 -> [1686] Connected to WiFi
12:56:44.541 -> [1686] IP: 192.168.1.147
12:56:44.541 -> [1686] Connecting to mqtt.mydevices.com:1883
12:56:48.528 -> [5687] Network connect failed
12:56:49.525 -> [6687] Network connect failed
12:56:50.525 -> [7687] Network connect failed
12:56:51.552 -> [8686] Network connect failed
12:56:52.545 -> [9686] Network connect failed
12:56:53.534 -> [10686] Network connect failed
12:56:54.529 -> [11687] Network connect failed
12:56:55.532 -> [12687] Network connect failed
12:56:56.527 -> [13686] Network connect failed
This was the code I used:
This example shows how to connect to Cayenne using an ESP32 and send/receive sample data.
Steps:
1. If you have not already installed the ESP32 Board Package install it using the instructions here: https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions.
2. Select your ESP32 board from the Tools menu.
7./
//#define CAYENNE_DEBUG
#define EspSerial Serial
#include <CayenneMQTTESP32.h>
#include <WiFi.h>
const char* ssid = “LinksysXXXXX”;
const char* password = “XXXXX”;
char ssidc = “xxxxxxxxx”;
char passwordc = “xxxxxxxxx”;
char username = “81fb6f60-aea3-11e6-9ce1-xxxx”;
char wifipassword = “3aa367aea0eb680fd4b444573f67cad7c060xxxx”;
char clientID = “2e444380-2d75-11e9-8cb9-732fc93xxxxxx”;
Serial.begin(115200);
WiFi.begin(ssid, password);
delay(500);
Serial.println(“Connecting to WiFi…”);
Serial.println(“Connected to the WiFi network”);
Cayenne.begin(username, wifipassword, clientID, ssidc, passwordc);
CAYENNE_OUT_DEFAULT()
Cayenne.celsiusWrite(1, 22.0);
Cayenne.luxWrite(2, 700);
Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
//CAYENNE_IN(1)
//for channel 1 commands.
CAYENNE_IN_DEFAULT()
[//getValue.setError](https://getvalue.seterror/)();
