share the full code, when you make any changes.
Apologies,
Please find below the full code:
//#include <CayenneArduinoDefines.h>
//#include <CayenneMQTTWiFi.h>
//#include <CayenneMQTTMKR1010.h>
#define RX 32
#define TX 33
#define CAYENNE_DEBUG
#define VIRTUAL_CHANNEL 0
//char ssid = “”;
//char wifiPassword=“”;
/* For Arduinoboards with multiple serial ports like DUEboard, interpret above two pieces of code and
directly use Serial1 serial port*/
int dist; //actual distance measurements of LiDAR
int strength; //signal strength of LiDAR
float temprature;
int check; //save check value
int i;
int uart[9]; //save data measured by LiDAR
const int HEADER=0x59; //frame header of data package
// Your GPRS credentials (leave empty, if missing)
const char apn = “internet”; // Your APN
const char gprsUser = “”; // User
const char gprsPass = “”; // Password
const char simPIN = “6317”; // SIM card PIN code, if any
// TTGO T-Call pin definitions
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
#define SerialAT Serial1
// Configure TinyGSM library
#define TINY_GSM_MODEM_SIM800 // Modem is SIM800
#define TINY_GSM_RX_BUFFER 1024 // Set RX buffer to 1Kb
#include <CayenneMQTTGSM.h>
char username = “6ef6eee0-7ee8-11e9-beb3-736c9e4bf7d0”;
char password = “27075a7d55000a07809e76b1286c5c2e52b2b78d”;
char clientID = “d64dced0-c644-11e9-8221-599f77add412”;
// Define the serial console for debug prints, if needed
//#define TINY_GSM_DEBUG SerialMon
//#define DUMP_AT_COMMANDS
#include <Wire.h>
#include <TinyGsmClient.h>
TinyGsm modem(SerialAT);
void GSM_SETUP() {
// Set console baud rate
SerialMon.begin(9600);
delay(10);
// Set-up modem reset, enable, power pins
pinMode(MODEM_PWKEY, OUTPUT);
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(3000);
// Restart takes quite some time
// To skip it, call init() instead of restart()
SerialMon.println(“Initializing modem…”);
modem.restart();
// Or, use modem.init() if you don’t need the complete restart
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN if needed
if (strlen(simPIN) && modem.getSimStatus() != 3 ) {
modem.simUnlock(simPIN);
Serial.println(“SIM Unlocked”);
Cayenne.begin(username, password, clientID, SerialAT, apn, gprsUser, gprsPass, simPIN);
void GSM_LOOP() {
void TFMINI_SETUP() {
//Serial.begin(9600); //set bit rate of serial port connecting Arduino with computer
//Serial1.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
Serial2.begin(115200, SERIAL_8N1, RX, TX);
void TFMINI_LOOP() {
// Cayenne.loop();
if (Serial2.available()) { //check if serial port has data input
//Serial.print(“*”);
if(Serial2.read() == HEADER) { //assess data package frame header 0x59
uart[0]=HEADER;
if (Serial2.read() == HEADER) { //assess data package frame header 0x59
uart[1] = HEADER;
for (i = 2; i < 9; i++) { //save data in array
uart[i] = Serial2.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)){ //verify the received data as per protocol
dist = uart[2] + uart[3] * 256; //calculate distance value
strength = uart[4] + uart[5] * 256; //calculate signal strength value
temprature = uart[6] + uart[7] *256;//calculate chip temprature
temprature = temprature/8 - 256;
//Serial.print(“HEllo5”);
Serial.print("dist = ");
Serial.println(dist); //output measure distance value of LiDAR
// This function is called at intervals to send data to Cayenne.
//CAYENNE_OUT(VIRTUAL_CHANNEL)
// CAYENNE_LOG(“Send data for Virtual Channel %d”, VIRTUAL_CHANNEL);
// This command writes the device’s uptime in seconds to the Virtual Channel.
// Cayenne.virtualWrite(VIRTUAL_CHANNEL, dist);
CAYENNE_OUT_DEFAULT()
//CAYENNE_IN_DEFAULT()
// CAYENNE_LOG(“Channel %u, value %s”, request.channel, getValue.asString());
GSM_SETUP();
TFMINI_SETUP();
GSM_LOOP();
TFMINI_LOOP();
your code looks good. I am not sure what to do mean by slow, where you still having Serial.println() code reporting which should have been SerialMon.println()
The code I used from WiMod provided libraries and examples is:
* This is a simple example file to show how to use the WiMOD Arduino
* library to communicate with a WiMOD Module by IMST GmbH
* http://www.wireless-solutions.de
* This example demonstrates how to start a LoRaWAN OTAA procedure to “register”
* the WiMOD to a LoRaWAN server
* - 1 WiMOD module running WiMOD_LoRaWAN_EndNode_Modemfirmware
* - Change the keys according to your LoRaWAN server before starting
* - Start the program and watch the serial monitor @ 115200 baud
// make sure to use only the WiMODLoRaWAN.h
// the WiMODLR_BASE.h must not be used for LoRaWAN firmware.
* Note: This sketch is for Arduino devices with two separate serial interfaces
* (e.g. DUE). One interface is connected to a PC and one is used for WiMOD.
* For single serial interface boards (e.g. UNO) it is recommended to disbale
#define WIMOD_IF Serial3 // for WiMODino use: SerialWiMOD
#define PC_IF Serial // for WiMODino use: SerialUSB
const unsigned char APPEUI[] = { 0xAC, 0xDE, 0x48, 0x23, 0x45, 0x67, 0xAB, 0xCD };
const unsigned char APPKEY[] = { 0xBE, 0xC4, 0x99, 0xC6, 0x9E, 0x9C, 0x93, 0x9E,
0x41, 0x3B, 0x066, 0x39, 0x61, 0x63, 0x6C, 0x61 };
ModemState_ConnectRequestSent,
* Create in instance of the interface to the WiMOD-LR-Base firmware
WiMODLoRaWAN wimod(WIMOD_IF); // use the Arduino Serial3 as serial interface
static TWiMODLORAWAN_TX_Data txData;
* Function for printing out some debug infos via serial interface
PC_IF.print(msg); // use default Arduino serial interface
void onJoinTx(TWiMODLR_HCIMessage& rxMsg) {
TWiMODLORAWAN_TxIndData txData = {};
wimod.convert(rxMsg, &txData);
debugMsg(F("joining attempt: "));
if (txData.FieldAvailability == LORAWAN_OPT_TX_IND_INFOS_INCL_PKT_CNT) {
debugMsg((int) txData.NumTxPackets);
void onJoinedNwk(TWiMODLR_HCIMessage& rxMsg) {
TWiMODLORAWAN_RX_JoinedNwkData joinedData;
debugMsg(F(“Join-Indication received.\n”));
if (wimod.convert(rxMsg, &joinedData)) {
if ((LORAWAN_JOIN_NWK_IND_FORMAT_STATUS_JOIN_OK == joinedData.StatusFormat)
|| (LORAWAN_JOIN_NWK_IND_FORMAT_STATUS_JOIN_OK_CH_INFO == joinedData.StatusFormat)){
//Ok device is now joined to nwk (server)
RIB.ModemState = ModemState_Connected;
debugMsg(F(“Device has joined a network.\n”));
debugMsg(F("New Device address is: "));
debugMsg((int) joinedData.DeviceAddress);
// error joining procedure did not succeed
RIB.ModemState = ModemState_FailedToConnect;
debugMsg(F(“Failed to join a network.\n”));
void onRxData(TWiMODLR_HCIMessage& rxMsg) {
TWiMODLORAWAN_RX_Data radioRxMsg;
debugMsg(“Rx-Data Indication received.\n”);
// convert/copy the raw message to RX radio buffer
if (wimod.convert(rxMsg, &radioRxMsg)) {
if (radioRxMsg.StatusFormat & LORAWAN_FORMAT_ACK_RECEIVED) {
debugMsg(F(“Ack-Packet received.”));
// print out the received message as hex string
[ debugMsg(F("Rx-Message: "));
[ debugMsg(F("]: "));](Profile - shramik_salgaonkar - myDevices Cayenne Community)
for (i = 0; i < radioRxMsg.Length; i++) {
debugMsgHex(radioRxMsg.Payload[i]);
// debugMsg(F("Rx-Message with no Payload received; Status: "));
// debugMsg((int) radioRxMsg.StatusFormat);
debugMsg(F(“==================================================\n”));
debugMsg(F("This is FileName: "));
debugMsg(F("This simple demo will try to "));
debugMsg(F("do the OTAA procedure and "));
debugMsg(F(“send a demo message each 30 sec.\n”));
// wait for the PC interface to be ready (max 10 sec); usefull for USB
while (!PC_IF && millis() < 10000 ){}
// init / setup the serial interface connected to WiMOD
WIMOD_IF.begin(WIMOD_LORAWAN_SERIAL_BAUDRATE);
// init the communication stack
// do a software reset of the WiMOD
// deactivate device in order to get a clean start for this demo
// do a simple ping to check the local serial connection
// try to register the device at network server via OTAA procedure
debugMsg(F(“Starting join OTAA procedure…\n”));
TWiMODLORAWAN_JoinParams joinParams;
memcpy(joinParams.AppEUI, APPEUI, 8);
memcpy(joinParams.AppKey, APPKEY, 16);
// transfer parameters to WiMOD
wimod.SetJoinParameter(joinParams);
// Register callbacks for join related events
wimod.RegisterJoinedNwkIndicationClient(onJoinedNwk);
wimod.RegisterJoinTxIndicationClient(onJoinTx);
RIB.ModemState = ModemState_ConnectRequestSent;
debugMsg(F(“…waiting for nwk response…\n”));
debugMsg("Error sending join request: ");
debugMsg((int) wimod.GetLastResponseStatus());
// check of OTAA procedure has finished
if (RIB.ModemState == ModemState_Connected) {
// send out a hello world every 30 sec ( =6* 50*100 ms)
// (due to duty cycle restrictions 30 sec is recommended
if ((loopCnt > 1) && (loopCnt % (6*50)) == 0) {
// send out a simple HelloWorld messsage
debugMsg(F(“Sending HelloWorld message…\n”));
txData.Length = strlen_P(PSTR(“Hello World!”));
strcpy_P((char*) txData.Payload, PSTR(“Hello World!”));
if (false == wimod.SendUData(&txData)) {
// check if we have got a duty cycle problem
if (LORAWAN_STATUS_CHANNEL_BLOCKED == wimod.GetLastResponseStatus()) {
// yes; it is a duty cycle violation
debugMsg(F(“TX failed: Blocked due to DutyCycle…\n”));
// check for any pending data of the WiMOD
Thank you very much for yuour support once more!Best
_salgaonkar Community Manager
March 24
if you have custom board then select cayenneLPP
in the device list and the device should send data in cayenne LPP format. the above code is not using cayenne LPP payload format.
Hi Shramik,
Is there an example on how to deploy LPP in my sensor’s and LoRa transceiver board?
Best
Spyros
you can try this arduino library for cayenneLPP GitHub - ElectronicCats/CayenneLPP: Library for Arduino compatible with Cayenne Low Power Payload
Shramik,
Thank you I did have a go previously and could not locate the lorawan.h library to donload. Is there a way around this?
why you need lorawan.h?
It is included in the following example script
Example of ABP device
Authors:
Ivan Moreno
Eduardo Contreras
June 2019
can you share a link to the example
Authors:
Ivan Moreno
Eduardo Contreras
June 2019
what are you sharing? there is nothing in the post,
Dear Shramik,
I had a close look at other confs found in Github and would like to update that I am using OTAA registration. Does this effect the LPP config?
I also had a look at the community posts and did not find any posts/examples on hot to setup LPP.
If you do have the chance to look at my code the next following days, I would be most grateful!
Best
Spyros
you can me the code which is sending data in cayenne LPP format based on the above library i shared above.
i dont see any cayenneLPP code in it.
I used the code found here:
oh, my bad, the library is recently updated. can you try adding this version Release 1.0.4 · ElectronicCats/CayenneLPP · GitHub and have a look at the examples inside.
Ηi,
Do yu surest altering and using the TTN example?
