I am trying to hook up my ESP8266 with a DS18B20 temperature sensor. I have seen in the forums that others have had issues but my error seems different. I can build the sketch but it won’t connect to wifi. I have confirmed with a basic ESP8266 that the board will connect to my Cayenne dashboard but with the DS18B20 code it keeps saying it kind find the DHCP server?
Cayenne DS18B20 Example
This sketch shows how to send DS18B20 Sensor data to the Cayenne Dashboard.
Steps:
1. Install the OneWire library (http://www.pjrc.com/teensy/td_libs_OneWire.html) from the Arduino Library Manager.
2. Install the DallasTemperature library (http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library#Code.2FLibrary) from the Arduino Library Manager.
3. Attach a DS18B20 to a digital pin on your Arduino.
Schematic:
[Ground] -- [DS18B20] -- [4.7k resistor] -- [5V]
|______________|
Digital Pin
4. Set the SENSOR_PIN value below to the pin number you used when connecting the sensor.
5. Set the VIRTUAL_CHANNEL value below to a free virtual channel (or the virtual channel of a DS18B20 Sensor widget you have added) in the Dashboard.
6. Set the Cayenne authentication info to match the authentication info from the Dashboard.
7. Compile and upload this sketch.
8. Once the Arduino connects to the Dashboard it should automatically create a temporary display widget (or update the DS18B20 Sensor widget you have added) with data.
To make a temporary widget permanent click the plus sign on the widget.
#include <OneWire.h>
char ssid[] = "TP-LINK_19FC";
char wifiPassword[] = "72731628";
char username[] = "9da66af0-74a3-11e7-8230-efa4c0c056b2";
char password[] = "6e6a62ac9d67f17282cbea3befd685412ffae409";
char clientID[] = "6108ff80-1de5-11ee-8485-5b7d3ef089d0";
#define SENSOR_PIN 2 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL 1
OneWire oneWire(SENSOR_PIN);
sensors.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
//Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL, sensors.getTempFByIndex(0));
