I am working on my new project but i have a problem. I am trying to control a rely based on soil moisture sensor.
Soil moisture value is shown on dashboard but i cant add a relay. Can you help me to solve this problem?
@shramik_salgaonkar can you help me ?
CODE OF THE PROJECT
#define CAYENNE_DEBUG
char ssid[] = "*******";
char wifiPassword[] = "********";
char username[] = "****************";
char password[] = "**************";
char clientID[] = "*****************";
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 5
int sense_Pin = 0; // sensor input at Analog pin A0
int value = 0;
Serial.print("MOISTURE LEVEL : ");
value = analogRead(sense_Pin);
value = value / 10;
Serial.println(value);
if (value <= 40) {
digitalWrite(ACTUATOR_PIN, HIGH);
else if (value >= 60.0) {
digitalWrite(ACTUATOR_PIN, LOW);
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(1, value, "analog_sensor", "null");
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
adam
June 29, 2022, 12:07am
2
The code seems ok to me. What is it doing or not doing? Any errors in the terminal?
I have only one problem, i cant control the relay.
Connections
Soil Moisture sensor…ESP8266 ( A0 ), its working.
Relay…ESP8266 (D5), its not working.
adam
June 29, 2022, 10:32pm
4
Does it turn on/off with your analog pin reading?
Yes, i can control the relay based on sensor data, but i cant control with Cayenne.
fprekupi:
Do you get logs in the serial monitor when you press the button in the UI?
In Cayenne always is shown a different value for the relay. You can see the screenshot below.
i meant logs in the Arduino serial monitor
@shramik_salgaonkar
With this code i can control the relay based on sensor data. But i cant control it using Cayenne.
In Arduino serial monitor is shown this.
keep serial monitor open and turn ON/OFF the button on cayenne dashboard. You should see some output in the serial monitor
@shramik_salgaonkar
When i turn ON/OFF the button on Cayenne dashboard, this is shown in the serial monitor.
@shramik_salgaonkar i am waiting for your help.
adam
July 9, 2022, 2:33pm
12
You’re using channel 0 for the relay, but in your code it’s connected to pin 5. Change the channel to 5 and it should work.
@adam I have changed the channel but it is still not working.
fprekupi:
In the code the channel used in 1
So you need to add button with channel 1 on the cayenne dashboard
@shramik_salgaonkar
Yes, i have added the button with channel 1 and its working.
Now i can change the relay state from Cayenne dashboard, but t have one more problem.
For example, when i want to turn off the relay, i touch the button on cayenne dashboard and its working.
But the relay turn on again because its programed based on sensor data.
What do i need to do, if i touch the button to change the relay state and to neglect the sensor data.
you can have this code inside an if condition with caynnen in value.
