Hello
someone has a ready project for one sensor ds18b20 with esp8622 wifi
#include <OneWire.h>
char ssid[] = "name";
char wifiPassword[] = "pass";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define SENSOR_PIN 4 // D2
#define VIRTUAL_CHANNEL 1
OneWire oneWire(SENSOR_PIN);
sensors.begin();
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL, sensors.getTempCByIndex(0));
//Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL, sensors.getTempFByIndex(0));
are you asking for an example code?
