- Device & model you are using (Ex: Pi 2 Model B or Arduino Uno with W5100 ethernet shield)
Raspberry Pi Zero W connected via WiFi - What dashboard are you using? (Web, iOS, Android)
Web - Please describe the bug / issue as detailed as possible. Attaching the code and any relevant screenshots would be very helpful!
What is the process to delete events from the schedule? Every time I have attempted to delete events from the scheudle it is access denied or can not delete this event. WHy?
Can anyone provide a resolution to this issue?
Thank you for you rhelp!
John
