Device & model you are using (Ex: Pi 2 Model B or Arduino Uno with W5100 ethernet shield) Raspberry Pi Zero W
What dashboard are you using? (Web, iOS, Android)Web
Please describe the bug / issue as detailed as possible. Attaching the code and any relevant screenshots would be very helpful! Currently trying to change the on/off times for relay. I received “cannot remove this event”.
